Question about Texas Instruments TI-83 Plus Calculator
Memory menu doesn't work.
When I press the MEM button (2nd +), nothing happens.
  • 10 Answers
If you are willing to reset it, hold the "CLEAR" button while you take out the batteries and then let go of clear, then put the batteries back in, and if that don't work, reverse the last two steps, and if that don't work, I suggest that you get professional help
Posted on Mar 05, 2009
Where is the reset button on a TI-84
Instructions
Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command.
Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Aug 29, 2012 | Texas Instruments TI-84 Plus Silver...
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
I stored a value for x. How do i clear it. I don't want to change it , I want to clear it. Thank You
Press 2ND MEM 2 to get into the memory management menu. Press 1 for all variables or select the appropriate type. Scroll down if necessary to the variable X. Press DEL to delete it. Press 2ND QUIT to exit the memory management menu.
Jun 28, 2010 | Texas Instruments TI-83 Plus Calculator
I need to clear the apps so that my students can test. What is the easiest way to do this?
You can reset all of the memory. The RAM, user data archive memory, and system variables are restored to factory settings. All nonsystem variables, applications, and programs are deleted.
Press 2ND [MEM] to display the MEMORY menu.
Select 7 to display the RAM ARCHIVE ALL menu.
Press right/arrow twice to display the ALL menu.
Select 1 to display the RESET MEMORY menu.
To continue with the reset, select 2. The message "Mem cleared" is displayed on the home screen.
May 21, 2010 | Texas Instruments TI-84 Plus Silver...
ERROR MESSAGE ON THE TI-83 TRYING TO GRAPH MESSAGE READS: ERR:MEMORY 1:QUIT CANT GET IT TO WORK ALREADY REPLACE ALL BATTERIES
To delete stuff from memory, press 2ND [MEM] 2 to display the Memory Management/Delete menu. Select the type of data you want to delete, or 1 for a list of variables of all types. Navigate through the list using up- and down-arrow and press DEL to delete the item from memory. Press 2ND [QUIT] to exit.
Feb 12, 2010 | Texas Instruments TI-83 Plus Calculator
Long delay/ the buttons do not work
The games you installed (or at least one of them is still in memory. Clear the memory and archive the games you do not play, it will free memory.
Press [2nd][MEM] [2:Mem Mgmt/Del] [7:PGRM]. A list of programs is displayed. To archive a program highlight it and press [ENTER]. An asterisk appears to the left of the program name. To exit press [2nd][QUIT] or just [CLEAR] and you will return to Home screen.
Hope it helps.
Sep 26, 2009 | Texas Instruments TI-84 Plus Calculator
My TI-86 calculator doesn't have a cursor. I can turn it on and adjust the contrast from dark to light but no cursor appears and nothing comes up when I punch any of the buttons!
Press [EXIT] or [2nd][QUIT] to terminate the program that may be hung in memory. Press [2nd] MEM[F3][F1][F4].
You may have to reset contrast.
1.Press and release [2nd] key.
2. Press and hold [UpArrow] to darken or press and hold [DownArrow] to lighten it.
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-86 Calculator
Erasing programs
2ND MEM to get to the Memory menu. Select Mem Mgt/Del. Select either Prgms or All. Navigate to whatever you want to delete and press DEL. Repeat as needed. Press 2ND QUIT when down.
May 28, 2008 | Texas Instruments TI-83 Plus Calculator
Can't reset
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 23, 2008 | Texas Instruments TI-83 Plus Calculator
Calculator will not come on
I have the same problem with the calc not responding to removing one batt and reinstalling while holding clear, etc. My fix is to hook up wires to the battery leads and plug the wire into a 120 volt outlet. Watch it light up, but do NOT breath the smoke as it is extremely toxic. ;-) lkw
Aug 25, 2006 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
93 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
