Question about Brother MFC 420CN All-In-One InkJet Printer
Added new cyan ink cartridge and won't print the blue colors
There was, I'm not sure if accidentally put in wrong, but a yellow cartridge in the space where the Cyan is to go and now after putting the Cyan cartridge in it still prints yellow. I have tried to print a bunch of copies to maybe clean it out with no results. Any ideas on how to maybe flush it or get it to work right?
Nope, It's just going to take lots of pages before it comes back...maybe the whole cartridge
Posted on Mar 03, 2009
Checked in Diagnostic cyan dispense motor and Cartridge motor working fine with cyan toner cartridge out, but when observed carefully by removing the cyan cartridge motor and coupling I could see that the D cut of cyan coupling was worn out as compared to other coupling of magenta , yellow, black. I put a packing of transparency in the D cut slot of the coupling so that the gear gives proper drive to the cyan toner cartridge and doesn't slip. The packing worked fine and the problem of customer was resolved.
Feb 05, 2011 | Xerox DocuColor 12 Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Have an MD 1300. printer begins then stops before actually doing the job. Get message: "cartridge change error - cannot complete print job." I have tried putting in a new cartridge but same...
What color are the cartridges that you are putting in? Are they blue or are they greyish in color? If you are trying to print on laser or other such paper, you need to be using the greyish cartridges. Also make sure that the cartridges that you put in have plenty of ribbon in them and that you've put them in facing the correct direction, you should be able to see the color names when you open the printer. If you don't, you've installed them facing the wrong way. Also make sure that you have all the correct colors installed for the print job. Unless you're printing strictly in black and white, you'd be surprised at what colors are needed to make a color, unless you're using pure Cyan, Magenta or Yellow. Any colors other than those will need to use a combo of those colors to reproduce colors properly. I hope this helps. If not, write back and say what steps you've followed to try to remedy the error.
Nov 18, 2010 | Alps MD 1300 Thermal Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Reports cyan cartridge empty but it is not
please remove all catridge
clean inside on the catrdge place space
put back the catridge
Oct 29, 2009 | HP OfficeJet Pro k550 Printer
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
Using the same cartridges for the HL-4070CDW, I refilled the black yellow cyan and magenta cartridges. when I put them all back into the printer, the RED toner life end comes on saying that cyan, magenta,...
There's a window on each end of the cartridges and light shines thru to show when they're empty, your refill toner may not be the right density. If you put a small piece of electrical tape over the windows on the cartridge, the error will go away, but you have to watch print quality to change or add toner.
Aug 11, 2009 | Brother HL-4070CDW Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Cyan ink Cartridge
Do you use generic ink carts?
If yes, try another one.
Alwasy make sure that the carts are placed well and are secured.
Answer the lcd question given by machine and check the magenta and the BK one, which could be empty, too!
Dec 28, 2007 | Brother DCP-315CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
123 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
