Question about IBM Computers & Internet
Want to use standerd ps/2 mouse port for keyboaord
I have ps/2 keyboard and usb mouse. The ps/2 keyboard port of my pc is out of order. Hence I want tpo use the standerd ps/2 mouse port for the keyboard. How can I change it?
I use xp on Ibm motherboard ----P4IBMS REV: 1.015-A20-010300
    Sergeant:
  • 319 Answers
You cant, the motherboard can be damaged by plugging the wrong input device into it. my advice, buy a USB KB.
Posted on Mar 03, 2009
I have a dell dimension 5150. I was attempting to upgrade drivers, and appear to have lost use of keyboard and mouse usb ports. As I cannot do anything on computer without one or other, its impossible to...
Are your devices wired or wirelss ? Have you tried another usb keyboard ? You could try booting up the machine, then switching the devices to another usb port and hope windows will reconize them. Last resort would be getting a real PS/2 keyboard at thrift store or if your really stuck, boot with a live-CD then you should have mouse and keyboard to try to copy drivers manually over to the windows folder.
Sep 29, 2013 | Dell Dimension XPS 400 PC Desktop
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
Mouse 6 pin ps/2 port on back of HP Pavilion Media Center TV m7680n not working it is enabled in bios where can i buy one online i need mouse and keyboard ps/2 ports to go ...
You are using the correct terminology.
Ps2 mice are far and few between. Use a USB mouse, likewise keyboard and add a USB to PS2 adapter.
Mar 21, 2011 | HP Computers & Internet
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
Keyboard and mouse not working
what sort of keyboard and mouse is that.. if its a serial or ps/2 then get the ps/2 to usb cable and try it using your usb port. if its usb mouse and keyboard then the better way is to get 4 usb hub and use it with hub.
hope it will solve your problem.
cheers
Apr 27, 2009 | Computers & Internet
1 USB Port Failure
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Nov 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
121 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
