Question about Jet 3 Ultra Power Chair
New battries won't charge.
I put new batteries in and they were fully charged I plugged the charger in for the 24 hours the book called for. I started using the chair but the batteries will not recharge.
I purchesed the chair used and the batteries were dead
  • Anonymous Mar 31, 2014
    My chair is an M91 I purchased used from a private owner. Believe it's a 2002 model. I've driven it hard and long so it may be terminal. It died the other day in a rain storm. After sitting for 48 hours, when I turn it on all the light illuminate and then immediately go out. I have new batteries but have not installed them. Is it likely that the new batteries will help? I have to figure out how to get the chair from where it died home to where the batteries are.
    Problem Solver:
  • 16 Answers
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Posted on Mar 06, 2009
My truck want crank?
you can charge with the cables connected
Sep 07, 2016 | Cars & Trucks
I accidentally left my EN-EL14 Ultra High Capacity Li-ion battery on the charger for 24 hours at least - is it toast? The manual that came with my Nikon D3200 says leaving a fully-charged battery on the...
Does the battery pack work? Leaving it on the charger for 24 hours shouldn't hurt the pack (too much) since the charger shuts off when the pack is fully charged. The most likely result would be a slight reduction in the capacity, but it should still work.
You shouldn't need to order another battery pack unless it no longer works.
Aug 22, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
S4500 Not Turning on
Is the battery fully charged? Try charging the battery for 24 hours and then try turning it on again.
Aug 25, 2012 | Fujifilm FinePix S4500 14MP, 30X Optical...
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Battery charging
I was charging newly purchase camera for hours, then I realized my battery was in upside-down. It took approx 2 hours to fully charge once I fixed the battery install!
Dec 03, 2007 | Jazz DV-179 Digital Camera
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Jet 3 Ultra Power Chair Logo
351 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
