Question about Kenmore 84052 Dryer
Can't seem to release the clips on lower front panel
Clips are supposed to be 4'' from the sides. But when I insert a putty knife I can't tell how to release the clip.
    Genius:
  • 1,122 Answers
Just take the 2 lint screen screws out and pull the top toward you and up-mike
Posted on Mar 04, 2009
I need to remove panel to access inside of Maytag washer model A207... how do i get in there?
insert a putty knife from the front into the bottom of the top lid panel between the lid panel and the front panel about two inches from both sides of the washer push the putty knife in firmly; this will release the hidden clips that hold the washer's top on and, allow you to lift off the top of the washer
Feb 04, 2013 | Washing Machines
How do I get the front panel off? I removed the clips on the bottom but it looks like there are clips toward the top on the sides. Do I go in through the back?
Insert a putty knife or a butter knife in the gap between the top and front about 4 to 6 inches from both sides. Depress the clips and raise the top and tilt back.
Nov 20, 2010 | Maytag MDE308DAYW Electric Dryer
Getting this message on the control board: notice a problem has detected with this machine
To remove the front panel-
1. Locate the two (hidden) spring clips between the top cover and front panel– look in that seam with a flashlight, you’ll seem ‘em. Or you can feel them with your putty knife.
2. Insert your putty knife and push forward on the clips to release ‘em.
3. The front panel will tilt out toward you and lift off the two hooks at the bottom.
There’s an LED on the board that will flash the error code. The location of the LED and its mystical flash code interpretation are HERE
Feb 09, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
How do you remove the front panel on a ge model wdsr2120j5ww
Use a small putty knife. Put the putty knife in between the front panel and the top about 3 inches in on the left and right side. You will be inserting it straight in toward the washer and this will release 2 clips and allow the panel to rock towards you. Note some pressure must be applied and will not always release easily. Once the panel rocks toward you there will be 2 clips on the bottom. Just pull off of the clips and you are done. To reassemble allign the panel with the bottom clips and push the top back in, again with a little pressure.
Thank you
Please rate this post
Jan 23, 2010 | General Electric WDSR2120J Top Load Washer
Did a load last night but will not start today. checked 30 amp circuit breaker but not tripped. replace 30 amp circuit breaker anyway. checked outlet for AC and seems OK for 220 volt. dryer is showing no...
There are no fuses inside dryers except thermal fuses, and they don't run the light. Check the connections where the cord hooks to the dryer. Is this a digital control dryer or does it have a knob? Some of the digital ones use the control box to run the light too, otherwise it must be a wiring problem.
Dec 06, 2009 | Maytag Dryers
How does one remove the lower front access panel on a Whirlpool gas dryer mode TEDL680AN?
Use a putty knife to separate the smaller bottom panel from the upper front panel.
About 2 inches in from each side there is a spring clip. Press the spring clip with the putty knife while pulling out on the edges of the smaller lower panel. It hinges down once it is free from the clips.
Nov 18, 2009 | Whirlpool LGQ9858L Gas Dryer
How do you open the front
OPEN TOP, 2 CLIPS RELEASED WITH PUTTY KNIFE, ONE ON EACH SIDE OF FRONT ABOUT 2"-3" IN FROM SIDE. CLIPS ARE ABOUT 3/4" WIDE. ONCE TOP IS OPEN, LEAN IT BACK IT WILL REST ON PLASTIC BRACKETS, YOU WILL FIND 2 HEX HEAD SHEET METAL SCREWS THAT HOLD THE FRONT TO THE SIDES. REMOVE THESE SCREWS AND TILT TOP OF FRONT PANEL OUTWARD. THERE ARE 2 LOWER BRACKETS THAT CONTINUE TO HOLD THE PANEL. THE PANEL CAN BE LIFTED OFF THESE ONCE THE PANEL HAS BEEN TILTED OUTWARD.
Nov 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't figure out how to get toe panel off on ?Kenmore HE4 dryer
The toe panel comes in various configurations. If yours has the retaining clips along the top seam as you mention, the easy way of getting them to release is to place a putty knife in the seam to depress the clip while pulling out slightly on the toe panel at the same time. Make sure you are inserting the putty knife on TOP of the clip and pushing DOWN. If you place it UNDER the clip it will not release. Repeat this procedure on the opposite clip as well. The panel should pop loose. On some toe panels there are screws holding the panel in place. Double check to make sure. I hope this helps you.
Mar 18, 2009 | Kenmore 84052 Dryer
Newbie Question
Look carefully under the front panel. there is a clip on either underside of the front panel. Insert a putty knife or screw driver in the clips to release. Pull the panel upward until the top clips are released. This is one of the best machines Maytag ever made.
Jun 23, 2008 | Washing Machines
How to replace the solid element on a ge modelJ37SVWX electric range
removing burned out solid element on heartland stove and replacing with new one..It is enclosed with a chrome ring on stove top
Nov 14, 2007 | Ovens
Kenmore 84052 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
