Fan capacitator size for Saxon 500 wood heater
Wanting to know what size fan capacitator the saxon 500 woodheater takes.
    Guru:
  • 462 Answers
The size is generally on the case of the capicator and is writtten in mfd or a kind of ufd or uf (the U stands for micro) F and FD = farads. The voltage rating is important but not nearly as mich as MFD. The voltage rating is how much voltage the capicator can stand before becoming critical. This capicator is usually mounted on the exterior of the motor.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK.
Posted on Mar 03, 2009
I have a Saxon that had the battery off and when I put it back in and put the code in keypad both green and red lights are on and will not start but turns over there is no spark at plugs.
Hi, Dave and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Troubleshooting No Start Honda Motorcycle
How to diagnose no spark situation on motorcycle
TROUBLE SHOOTING
Saxon Motorcycles USA
Mar 06, 2016 | Saxon Motorcycles
Complete service on saxon firestorm oil change plugs filters(types)
Buy the service manual is usually the best bet.
Otherwise call a local dealer or a bike workshop, they will usually have a listing of filters etc for most models.
Nov 19, 2013 | 2009 Saxon Firestorm
I have an opportunity to purchase a Saxon Refractor SEQ 900 x 90 Telescope but Saxon themselves tell me it is an obsolete model and they have no listing for it. Are you able to give me any advice? and can...
DO NOT BUY a Tasco telescope. They are not the best quality and the mounting for that scope will be shaky at best. Look elsewhere for a telescope. Here is one good brand:
http://www.telescope.com/control/main/
Jan 23, 2011 | Tasco Galaxsee 46114500 (500 x 114mm)...
Capicator For Saxon wood heater Fan
most blower motors are stamped with ratings on their nameplates which may include cap mfd and voltage, its worth a quick look
Mar 03, 2009 | Heating & Cooling
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
