Question about JVC RX-6000V Receiver
My JVC RX6000VBK does not get the signal from or to my subwoofer.
My JVC RX6000VBK does not get the signal from or send a signal to my subwoofer. The subs light is on but nothing. All other speakers are up and running fine. The light on the JVC showing if a signal is getting through is not coming on. All othe lights including the LFE are lit. Is there a separate fuse in the JVC for the subwoofer? Thanks.
  • 31 Answers
I had the same problem a few times, they are pretty picky receivers.
first take a look in your settings and make sure none of your speakers are set on large, if they are they automatically shut off the woofer,
2, try the adjust option and crank the bass and throw on the bass boost
3. manually turn the woofer on through the receiver itself
4. try and turn up the woofer itself if is powered
5. try hooking the woofer up to the secondary speaker jacks by bridging it, (positive on left and negative on right for even power)
if none of these options work then the woofer itself may be defective even though it lights up
Posted on Jul 01, 2009
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
I have the sub woofer and two sp-thc5f front speakers. Can I hook this subwoofer directly to my JVC 56 high def big screen or do I need a dedicated amplifier that works this sub wooofer?
No, the powered subwoofer gets its signal AND power through the DIN connector so you'd have to second guess JVC engineers on which pins are power or signal; and what voltage level it supplies and then you'd have to come up with a source for the power. Managing the volume and relative levels would be a trick, too. Devastation lies down that path.
Get the prescribed JVC electronics or go with a whole new sound solution.
Jan 16, 2011 | JVC THC5 Home Theater System with 5-Disc...
My jvc subwoofer inner speaker windings blow up and i m either willing to purchase the whole sub set or jst the inner speaker.the model number is sp-pw 105wd.theserial # 119k0101.
I would suggest to buy the entire cone speaker because the inner windings is harder to find or not available.
The cone speaker part number is: CR160058-01. Try contacting this website to find the cone speaker or you could find a cheaper speaker cone with the same dimensions and wattage.
I can also send you the service manual for this subwoofer.
Nov 27, 2010 | JVC SP-PW100 Subwoofer
My bass powered subwoofer on JVC system doesn't turn on
You need to check the signal. If there is not signal present or the volume is low the sub will not turn on and goes in to sleep mode.
-david
Nov 09, 2010 | JVC THC3 800 Watt 5-Disc DVD Home Theatre...
What color wire hooks up to my amp to subs
Should be a blue one or a blue one with a white tracer. Might be tagged antenna. Sends the signal wire on the amp the signal to turn on.
Mar 26, 2010 | JVC KD-G230 CD Player
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
Missing lead
typically i would say connect it in parallel to the right or left channel..assuming your system dosent have a sub woofer output and your subwoofer is powered
Mar 05, 2008 | JVC TH-S3 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC RX-6000V Receiver Logo
416 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
