Question about HP 430205-001 - HP Pavilion DV5000 Series Super Multi dual format, dual layer Drive Burner
I want to change fan for my laptop. - HP 430205-001 - HP Pavilion DV5000 Series Super Multi dual format, dual layer Drive Burner
    Problem Solver:
  • 3 Answers
For Example: If it is hp laptop You need to go to hp.com, click on SUPPORT & DRIVES, click on Select option 2 and type your product no. Click on the your laptop model no. and click on MANUALS. Click on Maintenance and Service Guide. You will get a manual in PDF format. Click on Removal and Replacement Procedure. Click on Fan/Heat Sink Assembly and follow the steps. It is easy. Good Luck. Amir
Posted on Jul 04, 2009
How do you change the fan in a laptop
Is the fan spinning? Have you cleaned the fan, vents, heatsink using a can of Compressed Air? You may have to dissemble the laptop to get all the dust out. Is the Laptop getting sufficient air flow through the bottom and out the side vents? Is there anything blocking it? A Laptop Cooler is one option. Depending on the CPU, you didn't post your Toshiba Model, there is a freeware program, SPEED FAN: http://www.filehippo.com/download_speedfan/ If the fan isn't spinning, take a look at this: http://www.youtube.com/watch?v=G2AcFvd9qjc
Apr 12, 2013 | Toshiba Satellite Computers & Internet
Compaq CQ56-219WM says system fan 90B is not operating correctly
this is what i did. Open my laptop, get out the motherboard and disconect the fan, change the termal sink, clean all inside, reconnect all and ready, then when you got it, change the cpu fan, i got it, it cost to me only 16.50 dlls. My laptop is now running properly.
Dec 27, 2012 | Compaq Computers & Internet
Loud fan
Chances are you have dirt buildup, get a can of compressed air, attach straw and give the cooling fan a few good blasts, blow out open ports. If no change, the laptop must be dismantled down to the motherboard level to do a complete cleaning and the cooling fan may need to be changed, the old thermal paste will need to be removed and fresh applied. Go to www.ebay.com Type: make and model of laptop, refine search to cooling fan.
May 10, 2012 | Toshiba Satellite L555D-S7910 Notebook
I need to find an CPU fans/Heatsink Part for my Compaq Presario Laptop Does any body know where to get tham at and cheap to??
you no need to change the heatsink only need to change the fan and visit your nearest whole seller and tell me to give you a one fan for your laptop. dont change the heatsink ok . just clean it well. may i know why you are chaning your fan? you having a slow speed of fan? just open the steaker of fan and you can see the hole there just put the few drops of oil and then try.
Apr 19, 2011 | Compaq Computers & Internet
Fan went out. how to repair myself
First you need to find out if you can purchase the fan,
http://www.sparepartswarehouse.com/Sony,Vaio-VGN-FJ-FZ-Series,Laptop,Fans.aspx
Now you need the Vaio VGN-FJ Series Service Manual,
http://tim.id.au/laptops/sony/vgn-fj.pdf
(PDF file download. Advise letting it download all the way, before looking through it)
Now post back if you need me to guide you. Looking at the procedures you need to follow can be daunting, if you've never done this before.
(Me? Oh yeah)
Nov 12, 2009 | Sony VAIO VGN-FJ270/B Notebook
My laptop alway run cpu cooling fan and get high sound from fan
Bikash, Do you know how hot the processor gets in 15 seconds. You cant touch it. So the fan keeps it cool so that you can work for hours without bursting the CPU. Sound is a different matter. Try feeling the bottom of the laptop. Where it is hottest try tapping a little softly. Is the fan has loose mounting or body or bearing the sound will change. If it does change, take it for repairs.
Aug 10, 2009 | Acer Aspire 3680 Laptop
Laptop fan does not engage when hot, but spins up upon boot
hi this is due to the fan settings in BIOS Program has been not correctly mentioned,so u cant find the fan setting in BIOS Program reset the BIOS Program it will helps u to activate the fan setting.when u got the fan setting u can solve the fan problem in ur laptop.In ur laptop fan is giving u the problem but the BIOS setting is creates the problem reset BIOS Pgm and then u can fix the fan problem without changing the fan again.
Thank u
Dnt Forget to rate me
Apr 21, 2009 | IBM ThinkPad A21m 2628 Notebook
The Fan on my Dell Latitude D600 laptop is clean, but not running. The Laptop in 6 years old. My OS is Windws XP Professional and I'm using Internet Explorer 6.0. The Service Tag : BJG8M The Express...
2 possible causes
1- the fan its broken and its need a replace one.
2- the thermal sensor of the mother does not funtion proprierly and need a change of mother.
1- solution try to buy a new fan and change it
2- 1 solution its a change of mother, but this is very costly, you will find external laptop fan, pad fan for notebook or something like that could do the work, if the notebook doenst shut down very often you will fine, because the notebook old dont raise a lot of temperature.
pd, Sorry my english
Apr 04, 2009 | Dell Latitude D600 Notebook
Noisy fan..
y dont u try to clean the fans by a vaccum cleaner or something like that. Also some of the screws might be loose, due tu jerks ,try to tighten them up.
Jan 24, 2008 | Compaq Presario Laptop
HP 430205-001 - HP Pavilion DV5000 Series Super Multi dual format, dual layer Drive Burner Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
