Question about Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
Whats the best way 1, a switch 2, wire it? If so how? Dave
pioneer AVH-P4000DVD
  • carlos alber Mar 13, 2009
    how do i bypass parking break without a switch
  • yiyasss May 11, 2010
    apparently no one knows the code to unlock this one :(
Ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Posted on Jan 13, 2010
Parking brake
better check on your dc wiring system make sure u have fixed them tightly
Sep 09, 2009 | Pioneer AVH-P4000DVD Monitor
Blurry lines when playing videos from iphone/ipod pioneer p4000
sorry i have attemptede this 3 times.
Facebook send login info to the last registered email address. You should ask for a reset option
Jun 19, 2009 | Pioneer AVH-P4000DVD Monitor
No pics on avh-p4000
Right after I send my problem with my p4000, I found what's where wrong... I forgot the little black wire ground. I simply put wires togheter (the big on and the small) and now, it works !!! I can see pictures and sound from DVD and listen music with USB flash drive...
Hope this will help you...
Phil
Jun 13, 2009 | Pioneer AVH-P4000DVD Monitor
It wont play dvds or any kind of video
Having the car in "park" is not the key. The unit needs to see a 'ground' on the light green wire that attaches to the parking brake. (see manual). You can get around this by installing a toggle switch OR a relay that will user the 'amp remote' wire as the trigger.
May 28, 2009 | Pioneer AVH-P4000DVD Monitor
No videp playback on Pioneer AVH-P4000DVD only getting sound !!!
Just wanted to add my 2 cents for those who might be having the issue of no video but hear audio. I was having the same problem. I had completed the bypass hack with a single throw/single pole (SPST) toggle switch. I could bypass the warning message and hit the OK button but no video. I did hear audio. I searched everywhere but solution 4 worked for me. The thing for me was that next to the black wire on the harness wasn't empty. It had a purple/white wire with some sort of filter (labeled backup camera hook to reverse gear). I tied into this wire before the filter with another wire (I chose a black wire b/c I was grounding it) and grounded it with the black wire (ground) on the harness. I now have video! Maybe the 4 pole relay hack would have worked better but I had only done the toggle switch hack. I hope this helps others and most importantly thank you Salhi.
Mar 26, 2009 | Pioneer AVH-P4000DVD Monitor
Im trying to bypass parking brake switch for pioneer AVH-P4000DVD. I already connected it to ground and then to power, but none of it works. I know that if i Install a toggle switch with 12volt current and...
This what you do. Connect the video wire to a power suppy and install a switch in the power wire. When you put the DVD in and the warning comes up, turn the switch on then off. This will allow you to watch the DVD without the park brake being applied.
Mar 21, 2009 | Pioneer AVH-P4000DVD Monitor
No video from ipod
Do you have the green cord that attaches to the parking break hooked up?
This stereo is designed so that you cannot watch videos while driving, therefore you need to have the parking break on in order to get video.
when you play a dvd with out the parking break on, you will only get sound.
Mar 18, 2009 | Pioneer AVH-P4000DVD Monitor
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
New pioneer dvd player cant view picture when playin dvd
You probably need to get the handbrake switch wire properly attached to the handbrake switch. Some people have also used a toggle switch or something and run the handbrake switch wire to that and the wire from the handbrake switch to a ground on the vehicle, then you just have to flick the switch off and on EVERYTIME you start the car to do the bypass.
Though what I'd really suggest just getting a 4 pin relay and do a bypass. You can also use a 5 pin relay and do it, just don't use the 87a pin. Another clean way to do it would be getting a PTR 7 but this costs a bit more and needs to be programmed. This should allow you to look at DVD's with vehicle moving or not.
Dec 20, 2008 | Pioneer AVH-P4000DVD Monitor
CHANGE REGION 1 TO 2 FOR AVH-P4000DVD
Kali Mera, Ti Kanis?
I have been looking in to this, but there does not seem to be a hack available.
http://www.videohelp.com/dvdhacks?dvdplayer=AVH-P4000DVD&hits=50
Signomi
Oct 24, 2008 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P4000DVD Monitor Logo
1,131 people viewed this question
Top Pioneer Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
