Question about Dremel Variable - Speed Multipro Rotary Tool 395
Dremel 395 doesn't seem to be getting any power. It's almost new
I've double-checked the plug-in--it works. I'm a pretty new home-user and don't know what else to check.
  • targetman96 Mar 26, 2009
    My dremel model 395 type 5 just stopped working. I've had it for 8-10 years and have used it only intermittenly. I purchased new motor brushes, but still doesn't work. I doubt it is still under warranty after all these years.
  • hootmon May 24, 2009
    stopped operating
  • 285 Answers
Return it for replacement. If your power source is good and you have pressed the ON switch/button and nothing works, it is likely faulty. If you are not familiar with pulling them apart, it is best not to! Seek a replacement (hopefully under warranty)
Posted on Mar 03, 2009
I took apart my Dremel 395 Type 3 and the spring popped out for the shaft lock. Where does the spring attach to?
It doesn't attach anywhere, that's why it popped out. It should just fit in a recess, pushing the lock button outward.
Sep 10, 2011 | Dremel Variable - Speed Multipro Rotary...
On the 395 Dremel, where can I buy a coupler?
HOME DEPOT OR ONLINE AT DREMEL.COM
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Rotary tool won't turn on or won't stay on but a second or two
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Apr 27, 2011 | Dremel Variable - Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Dremel model 395 went dead after a total of 25hrs use over 3years
Hello I am a woodworker also so I admire your project for your deaughter.
Your dremel 395 had a two year warranty. I would recommend that you get a new one or even a newly reconditioned one as the cost of the repair will be over 60 dollars. let me know what u decide to do......happy woodworking either way.
May 27, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
Mar 30, 2009 | Dremel Variable - Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 won't turn on. Was working fine last time I used it, now it is dead. Almost like the it's not getting power, but I have ruled that out.
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Aug 20, 2007 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
253 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
