Question about Milwaukee Tool Drills
Milwaukee hole hawg fan replacement
I was leaving tool mart the other day and they had a hole hawg that was on sale that i had passed by. the next day i called about it, the deal was too good of one to pass up. when i called they said they had taken it off the shelf it had a busted fan and i could HAVE IT FOR PARTS so i went and got it and removed the broken plastic fan but there is still the center metal knurl that held the fan in place i have tried a few different pullers but nothing has worked please help thanks
The fan need a press to be installed and uninstalled.... handed the tool off to the owner of my company for professional repair
Posted on Mar 08, 2009
Looking for a Milwaukee 48-66-1381 chuck kit with a 38-50-5075 spindle.
sure the age of the tool may have parts discontinued or superseded
this is a Milwaukee chuck kit you can buy
and a spindle on sale
try this Milwaukee parts supplier for a part or dimensions of the spindle/chuck you need
Milwaukee 1670 1 SER 472D Single Speed Hole Hawg Drill Parts 26309591-1jfwbypa2loxnuc0fythdbff-4-0.jpg
Oct 13, 2016 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Switch replacement
Go to e replacement parts and put your model number in and this will get you a parts break down.
Aug 10, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Aug 16, 2012 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How do I remove the chuck on my 1675?
Look down the barrel of the chuck, there should be a setscrew (usually torx)
this should unscrew counter clockwise. The chuck should also unscrew counter
clockwise with some coaxing. Hope this helps.
Mar 05, 2011 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Have a milwaukee hole hawg have lost chuck key where can i get new one in uk
I would just buy it online here...
http://www.bigdboltandtool.com/48-66-3280.html
heatman101
Jan 17, 2011 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Slipping in high speed
It seems like the "CHUK BEARING" is burn. Go here and look around -.link.
Oct 12, 2010 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Need forward/reverse switch for older red and metal heavy duty 1/2 inch 7amp milwaukee drill serial number 0007196072.
Link to find parts list:
http://www.milwaukeetool.com/CMS/Diagrams/54-10-4006.pdf
You can google the 23-66-1020 part number and find numerous suppliers.
RECALL NOTICE!
Milwaukee is providing a no-charge warranty service to owners of 1610-1, 1630-1 1/2" Compact Hole-Shooter Drills and
1670-1, 1675-1 1/2" Hole-Hawg® Drills. We are taking this action because under certain circumstances the switch of the drill
may stick in the "on" position, which could lessen control of the product, posing a risk of injury to the operator.
1610-1, 1630-1 1/2" Compact Hole-Shooter Drills and 1670-1, 1675-1 1/2" Hole-Hawg® Drills within the serial number
ranges shown below and sold between May 30,2000 and February 27, 2001 are affected.
Nameplate Catalog Number Serial Number Range
1610-1 700B400200013 thru 700B400480097
1630-1 718B400230057 thru 718B400480118
1670-1 472B400200061 thru 472B400440188
1675-1 413B400190567 thru 413B400522000
Drills listed should be inspected for the presence of a 23-66-1020 Switch with a date code within 0 0 2 1 t h r o u g h 0044.
If the unit contains a subject dated coded 23-66-1020 switch, please return drill to the nearest Milwaukee factory Service Center
or Authorized Service station for no-charge warranty replacement of the switch.
Affected switches carry a manufacture's four [4] digit date code of 0 0 2 1 t h r u 0044 imprinted on its body.
If nameplate has an 'X' stamped into the tool's nameplate, next to the catalog number, the tool has been repaired and the
defective switch has already been replaced.
If you need assistance in locating the service facility nearest you or have questions please call 1.800.729.3878
Oct 05, 2010 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How do you remove chuck?
There is usually a bolt inside the center of the chuck in addition to it screwing on the spindle. The bolt may be an Allen or Torx.
Jan 12, 2010 | Milwaukee Tool Milwaukee 1680 21 1/2"...
How do I remove the chuck off a milwaukee hole hawg. Ihave removed the screw inside the chuck and have tryed to trun it off but it wont move.
With the lock screw removed (it's a reverse threaded screw) you can procede with getting the chuck off the drive shaft.
OK, you need to put a 1/4" or larger hex key wrench into the chuck and tighten it in place with the chuck key. Put the short end into the chuck.
Once you've done that, place the drill chuck, only the smooth part, not the part with the teeth, on the edge of a solid workbench. Now hold the chuck with the hex key (long end) at a 30 degree angle off the bench top and strike the hex key with a hammer going counterclockwise (looking at the front of the tool) to loosen the right hand threads that hold the chuck to the shaft (spindle). You should now be able to easily remove the chuck by hand at this point.
Here's link to a manual for your Hole Hawg that will also show a nice illustration of the removal method, to make it a bit easier, as well as giving you other good info about your drill. Print a copy for your files and future reference.
http://www.milwaukeetool.com/CMS/Diagrams/58-14-1782d9.pdf
That should do it! Hope you find this Very Helpful and best regards!
Jun 13, 2009 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Drills Logo
104 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Iron
Iron
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
