Water Heaters
Problem for Honeywell Water Heaters
Generic problem for all Honeywell Water Heaters
Hot water out of taps is not very hot.
By hunny_do on Mar 03, 2009
Even when I turn the temperature control dial to the hottest setting on the hot water tank, the water still isn't very hot. Is there some sort of a safety valve or a way to get the water out of the taps hotter? Or is this simply a problem with the tank itself? I'm not 100% sure of the brand of the tank. I will double check and edit the post accordingly.
Best Solution
posted on Mar 03, 2009
Helpful)
tankless1
Rank: Guide
Rating: 92%, 2 votes
What is hot? Above 122F causes scald within 30 seconds. Get a temperature reading at tap. Use a candy thermometer if need be. If you want 140F water then your gas valve needs replacing.
In most code areas it is now illegal to deliver tap water over 125F to a consumer faucet.
You may love 140F but you jeopardize kids and Seniors.
Was this helpful?
Yes
No
Questions and Unsolved Problems for Water Heaters
Answer
They say to clean the board and the sensors with canned air. This will usually work for me, but this... (More)
Answer
(electric 240v 50 gal.,3 yr old)breaker on unit(not elec service panel) trips every afternoon-not... (More)
Answer
I need a manual or part number for the bottom heating element in a GE Smart Water Heater GE50M6A
Answer
the power panel is flashing and water is not getting hot
Answer
Our hot water heater keeps needing to be reset. Twice we've found ourselves with no hot water and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Water Heaters Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
