Question about Office Depot Ativa Wireless-G USB Network Adapter (AWGUA54)
File unseen I have a Ativa usb drive with 8GB. But this morning I can't seem to see any of the files. When I go to properties it shows that 4GB of storage is still free. How can I retreive my files. Is there a free software that you could recommend to recover those files.
  • 38 Answers
Make sure the files didn't just accidentally get set as hidden. To check this open the folder or the drive in my computer and click on tools > Folder Options. Scroll down to view ALL files. Refresh My computer by pressing F5 and see if they are now there.
Secondly if they were deleted try this free software http://undelete-plus.com/ .
It works wonders.
Good Luck!
Posted on Mar 05, 2009
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that...
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have deleted some folders from the drive, cruzer micro 8gb, and now I have a file called "ReadyBoost.sfcache" sitting in the drive taking up 4gb in space that I cannot delete or remove.
click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
click on your usb drive select format
or you might have to open up the ReadyBoos.sfcache tfile and delete the files individually
also right click on each file select properties to make sure you have full control
if you need more help with this post a reply
hope this helps you
Sep 14, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When I plug my Maxell 8Gb 360 usb thumb drive into my computer at work, which is running XP, the OS can see the whole 8Gb, but I cannot put a 4Gb file on the stick. However when I use my windows 7 laptop...
Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
Jan 06, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
Trying to put 6.56GB movie on my 8GB sandisk cruzer contour, says the file is too large for the destination file
The file system is likely the culprit for this. If you've formatted the USB stick with FAT32, the largest SINGLE file will be about 4GB. You can place as many smaller files as you want to fill the stick completely (in excess of 4GB), but once you approach 4GB for a single file - it will crash.
Format with NTFS instead. No 4GB limit is placed on files in this file system. A nice chart listing the differences between file systems can be found here. The forth row "Max File Size" shows the data you're asking about. NTFS supports 16TB (terrabytes are 1000 times larger than gigabytes) while FAT32 is limited to a "paltry" 4GB. Both FAT32 and NTFS are supported by Windows XP and newer OSes.
I hope this helps - please rate my reply - thanks!
Dec 28, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Hi....io am unable to upload ne file tmy 8gb
If your flash drive has a small slide lock switch on the edge of the flash drive, then slide this switch to the Read/Write position.
Jul 12, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
KINGSTON removable disk error
Find and check real free space go to my computer and right click your driver letter and click properties it will show what is real ammount of disk. For one 4GB file it must not be problem but for meny little file can take more space besider their sum of capacity is 4GB. At format check correct ammount of data "capacity" is 8GB (7.9) also file system for NTFS or FAT32. FAT cant bear 8GB.
Aug 04, 2009 | Computers & Internet
Cannot copy 4.53 GB mpeg file to 8GB pendrive
http://www.kingston.com/support/USBFlashDrives/faq/pcdt_30.asp
Jul 09, 2008 | Electronics - Others
Office Depot Ativa Wireless-G USB Network Adapter (AWGUA54) Logo
91 people viewed this question
Top Office Depot Computers & Internet Experts
Isabella Lee
Isabella Lee
Jonathan Ashkenaze
Jonathan Ashkenaze
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
