Question about General Electric PSCS3VGXSS Stainless Steel Side by Side Refrigerator
G.e. refrigerator not cooling. A signal comes up that says "D.E."
Refrigerator is 3 years old and all of a suddedn just stoped cooling. It send a message tha saysDE.
Is this refrigerator had it?
  • 410 Answers
The DE code that you are seeing means the refrig is not sensing a defrost cycle. There ar 3 possible causes,
  • first and most likely is a shorted defrost heater heres the part number WR51X10055 this part is less than 50.00. If you are mechanicaly inclined it is a very easy repair that would take about an hour to complete.
  • Second would be a bad defrost sensor this part turns the heater off to prevent over heating or possible fire. this is also a part of the heater assy mentioned in the first possiblity and I recomend replacing the heaters along with the sensor.
  • Last and least likely would be the computer control board located on the rear of the refrig. again this part is an easy repair the part number is WR55X10775 and cost is around 250.00 in my experience this is only the problem about 10% of the time
If you are not sure about doing this repair your self you can manually defrost the unit by off loading your food and unplugging the refig leave the doors open for about 4-8 hours to allow the unit to defrost manualy. this will get the unit working temporarily until you can have it repaired.
If you would like instructions for replacing any of these parts message me back and I'll walk you thru it.  thanks Peyton
Posted on Mar 03, 2009
I have an NEC refrigerator model FR480 eight years old that has stopped cooling. Called the technician who can't get information with regard to the electronic controls. It appears that the compresor and...
Hi, do you mean the signal to stop cooling is faulty?
I guess the thermostat is faulty. Its the one which detects the temperature and send signals to the circuit.
Oct 10, 2008 | Refrigerators
F&p beeping,pressed green button beeping stoped but now fridge and freezer not cooling greenlights flashing?
HI,IF YOUR REFRIGERATOR IS BUILT WITH DIGITAL TEMP CONTROL ,PROBABLY THE PROBLEM COULD BE A BAD SENSOR ,BAD COMPRESSOR,OR BAD CONTROL BOARD,IF YOUR FRIGE IS LESS THEN A YEAR OLD MAY BE UNDER WARRANTY ,CONTACT THE FACTORY TECH DEPARTMENT FOR DIANOST AND SERVICE..
Feb 21, 2011 | Fisher and Paykel Active Smart E522B...
Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Apr 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My KitchenAid KBRS22K bottom mount refrigerator is eight years old. Was working fine, but now the refrigerator does not cool, but the freezer stays cold. The fan seems to work and the coils have been...
the problem here is the defrost element is not coming on, the problem is the control board in the fresh food compartment is defective and not telling the element to defrost. Therefore your cooling coils are impacted with ice which keeps freezer cold, and sensor in freezer says everything is ok and therefore sends nothing to refrigerator. Replace the defrost control board, Thaw out the cooling coils in freezer, and your back in business
May 19, 2009 | KitchenAid KBRP20EMSS Bottom Freezer...
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
KENMORE ELITE REFRIGERATOR MODLE #106.53606201
Compressor is cycling on the overload protector. If refrigerator is over five years old the warranty may be expired. I which case I never recommend replacing the compressor if the customer is to bear the full expense.
Jul 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
General Electric PSCS3VGXSS Stainless Steel  Side by Side Refrigerator Logo
185 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Are you a General Refrigerator Expert? Answer questions, earn points and help others
