Question about GE WVSR1060A Top Load Washer
Overflowing water. Water keeps running and will not stop.
The water fills up the tub and will not stop. It keeps overflowing. Pushing in the knob will not shut the water off either. I have to turn the water off at the spicket. When the water is stuck on, I can take off a yellowish clear hose on the left side of the tub, blow air into it, something makes a clicking noise, and it stops the water. Kind of like some sort of float is stuck and the air being blown into the hose moves the float. As soon as I stop blowing air into it, it runs again. I also blew air into a small box on the lower left side of the tub that the hose plugs into and it fixes the problem for a few loads. Then the problem happens again.
    Scholar:
  • 106 Answers
Shut the faucet on the wall, disconnect your hoses to see if there are debris blocking the fine meshes, clean this out, as well as the mesh on the machine. If these don't work change the inlet valve, it is easy you can do it yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com You can give me a good rating......
Posted on Mar 03, 2009
  • 188 Answers
The hose you're blowing into is the pressure switch hose. It connects between the tub and the pressure switch which controls the water level.
Basically, as the water level rises so does the air pressure in the hose and pressure switch. When there is enough air pressure inside the pressure switch, a diaphragm contacts a switch (clicking sound) and shuts off the inlet water valve.
This hose will sometimes stretch with time at the connection points. When this happens, air is able to escape and therefore never builds enough pressure to activate the diaphragm.
Obviously, replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (diaphragm side and tub side) and reconnect making sure to push hose ends securely onto connections.
Alternatively you can use small clamps on each end.
If this doesn't work, you may need to replace the pressure switch.
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The belt broke, it was replaced, but afterwards its overflows,
If water is overflowing check the small plastic line going from the bottom of the tank to the water level switch. It could be disconected. To check the water vales, set machine to fill, while the water is running into the tub unplug the power cord from the wall, the water should stop, if not the water valve is faulty.
Oct 11, 2009 | Speed Queen Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't stop filling with water
Does the water continue to run when the washer is unplugged from power?  If it does, then there is something stuck in the inlet valve that is keeping it open.  Could be the result of mineral deposits.  If the water stops when unplugged then the water limit switch is defective.  Unlikely since the water still flows when control knob is in off position.
May 29, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Mar 15, 2008 | GE WVSR1060A Top Load Washer
Washer overflowing from the tub
There's an air tube connected to the back of the water level switch, If that is kinked/pinched/crimped/disconnected or has a hole in it... the pressure switch will "think" there's no water in the tub and thus continue to fill it. Access your control panel and verify your air tube connection @ the level switch.
Aug 09, 2007 | Frigidaire FWS845GF
GE WVSR1060A Top Load Washer Logo
141 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
