Question about Mitsubishi Televison & Video
Lamp light went on.
My mitsubishi tv just turned off an now will not turn on, plus a light called lamp turned on.
    Genius:
  • 1,139 Answers
Hello mikiestrada1,
This means that your lamp has malfunctioned, and needs to be replaced. The procedure for rpelacing your lamp should be in your owners manual, or you can find the schematic/service manual on line at www.servicemanuals.net
Once you replace the lamp make sure you put it back exactly as the instructions in the service manual tells you to.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 03, 2009
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
http://www.shopjimmy.com/mitsubishi-915b403001-dlp-replacement-lamp.htm
May 08, 2014 | Televison & Video
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
The picture on our Mitsubishi 1080P went off but
Ur tv have been on using like 4 or 5 hours a day?This tv have not been replaced it projection lamp?The lamp in the tv used like a 1 or 1 1/2 years?The projection lamp life is over,replace the lamp.
Jun 15, 2010 | Mitsubishi WD-60735 Projection Television
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
TV went out and will not turn on
try rehooking up your cable for your tv, if it dont work just call your tvs manufacturer
May 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
