Question about GoVideo Go Video DVD/VCR Combo
THE DVD DRAWER WILL NOT OPEN!!
I HAVE THE GO VIDEO DVD-VCR COMBO - MODEL NO.2015.
MY PROBLEM IS THAT THE DVD DRAWER WILL NOT OPEN. I PUSH THE BUTTON AND IT WILL READ OPEN ON THE DISPLAY WINDOW, BUT IT DOES NOTHING.
THE OWNERS MANUAL HAD NO HELP.
ANN MARIE
  • maroon_051 Mar 03, 2009
    TO FOOBARPH,
    THANK YOU SO MUCH FOR YOUR SUGGESTION!! AT FIRST IT DID NOT WORK AND I GOT SO FRUSTRATED!! I FINALLY TRIED AGAIN JUST MOVING THE OPEN PAPER CLIP AROUND AND I MUST HAVE HIT THE RIGHT SPOT BECAUSE IT OPENED!! IT CONTINUES TO OPEN NOW!!
    THANK YOU SO MUCH FROM MAROON_051@YAHOO.COM!!!
Try using paper clip to open your dvd drawer.
Posted on Mar 03, 2009
  • foobarph Mar 03, 2009
    Glad to hear that Ann Marie! In case you have any more problem, contact me at my YM (foobarph)
SOURCE:
Cannot get the dvd out of my recorder, will not eject with remote or the button on the recorder
Look on the face of the DVD drawer. You will see a tiny hole in it. Straighten a paper clip and push it in the hole until it stops. Push further and the drawer will open mechanically far enough for you to grab it and open it completely.
Jul 28, 2017 | Magnavox MWR20V6 DVD Recorder VCR Combo
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Magnavox ZV427MG9 DVD Recorder VCR Combo DVD tray is stuck in open position. Pressing close button results in slight jerking motion of tray followed by display of "close", then "load" ...
There is typically a small rubber belt or plastic gear that goes between the tray motor and the tray. Most modern units have the plastic gear. I would bet that it is missing a tooth or stripped its teeth or possibly fell off completely. You should be able to manually push the drawer in. To open it, there should be a small hole near the tray into which you can push a straightened-out paper clip.
Mar 05, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
The DVD drawer won't open and close on our Go Video VR3845 combo. Help.
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Dec 31, 2009 | GoVideo VR3845 DVD Recorder/VCR
Go video ht2015
there's a black band that connects the motor to the pulley that opens the drawer.....this band has been burst.
easy to replace by using a small rubber band.
just finished doing this with my one.
now the drawer opens and closes ok.
Oct 23, 2008 | GoVideo Go Video DVD/VCR Combo
The DVD drawer will not open
I have the same problem. Best way to open the door is to hit the eject button and then bang lightly on the door using the remote controller. Works every time.
Mar 31, 2008 | GoVideo Go Video DVD/VCR Combo
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Dvd drawer will not open
seems like the rubber band is broken. no there is not secret back door to it..you have to open it and change the rubber band. it is not that complicated
Mar 26, 2007 | Philips DVD750VR DVD Player/VCR
GoVideo Go Video DVD/VCR Combo Logo
415 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
