Question about JC Whitney Flip Down Monitor From
FORD F150 2004 FX4
The overdrive light in the dash doesn't light up when I push the overdrive button on.I think the transmission is not shifting into overdrive because my gas mileage has decreased by 3.5miles to the gallon on the highway(was 17.5mi now 14.0mi) I'm thinking maybe the overdrive button is bad or the wires are disconnected.I would appreciate any advice,Thanks
  • eojanc Mar 04, 2009
    First,should I start at the O.D button and work my way to the light? How do you get at the overdrive button on the console shift?Plus is this the problem with the mileage or something else
  • 19,396 Answers
Hi there , if the transmission is not shifting into overdrive, then the overdrive fuse had probably blown.
The fuse should be : Fuse # 29 5A Transmission overdrive control switch.
Check the fuse, and if the fuse is fine, check the overdrive wirings on the steering column.
Do not forget to leave me feedback on this, that is important for us.
Thanks.
Posted on Mar 11, 2009
    Sergeant:
  • 239 Answers
Check uder the truck and make sure that the wires don't have any build up on or aroung them this could cause your problem. also make sure your transmission fluid level is good. and check the fuses under the hood of the truck there should be a tranmission fuse of some sort.
hope this helped
please rate well
Posted on Mar 04, 2009
  • 744 Answers
Try to pull ur plugs and inspect for carbon build up on any of the plugs... If you find one or two, clean them up good, or replace them & test drive it... it will solve ur problem...
thank u!!
    Novelist:
  • 166 Answers
Check there might be some wire fault.
check all wires connected to light.
The Transmission shifts very hard after the first shift. Check engine light is on as well as the Green overdrive light blinks off and on. Speed sensor was cleaned and even replaced.
Your on the right track. Have you scanned the PCM, what codes did you get? If not and you changed the vehicle speed sensor,(VSS) did you check the (OSS) output shaft speed sensor, it will cause torque converter lock up and hard shifting and that pesky OD light flashing. I have also found that clutch packs inside auto tranny's dry out. Ford and some aftermarket companies sell a fluid that will recondition the clutch packs.
Mar 10, 2015 | 1997 Ford Thunderbird LX
97 Ford f150 xlt rear wheel drive. transmission not shifting into 3 shifts from 1 to 2 fine when in overdrive shifts in to 3 feels like neutral. Trans need rebuilt or replaced?
Are there any lights lit on the dash ? check engine , overdrive etc..
could be just a shift solenoid ... Try draining trans fluid an replacing filter. Have to drop transmission pan .. what's the fluid look like ? a nice pink color ? does it smell burnt ? Is it full ?
Feb 25, 2015 | Ford Cars & Trucks
Why is my overdrive light flashing on my 2005 ford focus
That is what is called limp mode does the transmission shift gears real hard you need to Pull transmission codes and see what is the problem
Feb 13, 2015 | 2005 Ford Focus
1996 honda accord wont shift into overdrive
For Automatic transmission problem,click the link below:----Overdrive light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
--------- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Mar 04, 2012 | 1996 Honda Accord
I have a light on my dash that says o/d off
i assume that you have a sentra 1997 automatic transmission. OD orange light on your dash means that your overdrive is not engaged meaning your sentra is not on fuel efficient mode.
solution: in your automatic stick shift, driver side is a button just below the T bar. press that button until the OD light dissapears on your dash. you're now in overdrive mode.
Jul 15, 2010 | 1997 Nissan Sentra
Transmission shifts ony 123 no overdrive, it slip in overdrive
sorry to say this trans has to be removed and rebuilt seems like od clutches burnt out-do you tow heavy trailer with truck as you have to tow with od off(push button on shifter)
Oct 05, 2009 | 2001 Ford F150 Styleside SuperCrew
Push button overdrive column light flashes, which fuse controls it? transmission still shifts through all the gears, including reverse, overdrive is the only problem
the flashing overdrive light indicates a code for the transmission you need to have your codes read to see what is causing the problem
May 10, 2009 | 1995 Ford Bronco
"Overdrive Off" light on dash keeps blinking
I had the same problem took it to the dealer and it was a sensor inside the transmission.
Feb 11, 2009 | 1999 Ford Explorer
A light on dash saying o/d off came on
There is a small button on the gear shifter. This is the OverDrive switch. When the button is depressed "IN", the overdrive system is active, and the light on the dash is off. When the button is OUT, the overdrive system is de-activated, and the light on the dash is illuminated. The OverDrive is basically the final shift of the transmission, which gives you maximum fuel economy. When the light on the dash is ON, the OD is "OFF", the transmission will not make its final shift, and will lower your fuel economy. It is best to leave the button IN, and have the OD system active. Hope this helps, and Thanks for Choosing FixYa. The graciousness of a "FixYa" rating for my solution would be greatly appreciated. Thanks for allowing me to help you with your issue.
Nov 19, 2008 | 1999 Toyota Camry
1998 Ford Explorer
there is an sensor on the speed odmeter cable on the side of transmission. it will kill thr overdrive and cruise control but not the speedometer. about $50.fixed 2 explorers that way
Jul 09, 2008 | 1998 Ford Explorer
Car Audio & Video Logo
80 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
