Question about Nintendo Wii Console
Can get only grainy black and white color on our new Wii.
Have a great tv - so we know that nothing is wrong there.
  • dawata Mar 03, 2009
    I have one more thing to check, but that sure sounds like it might be it. Where you can choose HDTV on the Wii Sports - it wouldn't let us - only Standard. Probably because we needed the five prong vs the 3.
    Well, got the 5 pin cable and that didn't work either. Still think that when you are setting up the game and it wants you to select "Standard TV" or "HDTV", and it makes us choose "Standard" when we have an HDTV, is one of the big problems, but we just can't get it to the point where it will. We disconnected our Bose Stereo that our TV runs through - thinking that may be the problem, but it still doesn't work. We have tried using the panel in the front of the TV to set the game up and also in the back - still nothing. Might need to go to Best Buy and talk to someone there - that's where we purchased it. Do you have any more suggestions?
Went back to Best Buy and purchased a Component Video Cable. It's working just fine now!!
Posted on Mar 03, 2009
If you have HDTV do you have a 5 pin cable?  Nintendo say that the most common reason for tis problem is that HDTV's  need a 5 pin component cable in place of the standard 3 pin cable which is supplied.
N64 colors do not work when hooked up to Vizio TV.
You probably have the RCAs in the component video hookups. Its easy to confuse them as they are similar ports. They are usually red, blue, and green. Look for the yellow, white, and red hookups. Those are for RCA connections as they don't work in the component hookups for HD video. i.e. blue-ray, PS3 That will cause the video to look grey and grainy.
Sep 14, 2012 | Nintendo 64 Console
I just got a new 46" vizo & dont know what ports to plug my wii into? i know the cords are red white & yellow but not the ones on the tv. totally confused.
Many large HDTV's will have alternately colored slots to enable 5 connector HD cables. You can plug the Red White and Yellow cords into non-matching ports (green, black, etc) until you have color picture and stereo sound. This will not damage your TV or Wii. You can also buy cables for your Wii that will match the connectors on the back of your television, as well as give your Wii higher resolution capabilities. Which you can purchase at any electronics store.
Mar 14, 2011 | Nintendo Wii Console
Wii is 2 years old just got new tv set wii up and wii has no colour/sound. Colour is grainy black and white and sound only comes out of the wii remote.
please check your cables and make sure that they are on the right ports. simple solution. nothing wrong with your wii. New Tv can be a little confusing. remember just keep your wii on and test the ports till you get the right ones. If other devices are working such as dvd player then you need to replace the cables
Jun 13, 2010 | Nintendo Wii Console
Wii Console: We just bought mario bros for the wii. We have a s...
The wii doesnt go black and white by itself. It's your t.v.
May 05, 2010 | Nintendo Wii Console
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
No Color Picture
Are you using the Red/Green/Blue cables or are you using the Red/Yellow/White?
Also make sure you are matching the colors up correctly. If you find that you only have two of the three RYW, try hooking it up to another AV jack on the side or front of the new TV. If you are using the RGB, sometimes in low light settings, the blue and green are easily mixed up.
Another thing you might want to try is changing your settings on your tv for NTSC as it might be set up for PAL.
Dec 15, 2009 | Nintendo Wii Console
TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
Nov 23, 2009 | Nintendo Wii Console
My wii doesn't have full range of color.
Just because it's new, doesn't mean that it's not broken.
Double check the cables. Make sure that they are plugged in to the proper ports.
Take the Wii to a friends house and plug it into his TV. Verify that the problem is with Wii and not the TV.
Nov 18, 2008 | Nintendo Wii Console
New Nintendo Wii
check you've got it on the right PAL/NTSC setting.It's very likely the 50/60hz setting. 480i running at 60hz is NTSC resolution although the PAL Wii of course uses the PAL signal. The TV probably tries to interpret the signal as a real NTSC signal because it's 480i 60hz and thus can't handle the colors. There has got to be an option to switch between NTSC and PAL.
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
Oct 23, 2008 | Nintendo Wii Console
Screen losing color.. turning black and white
Your TV goes black & white, because your Wii could be NTSC or PAL which. If your Wii is PAL and your TV is NTSC then the TV will show a blac and white color. Since NTSC is for North America and PAL for Asia
Jan 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
168 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
