Question about Acer Aspire 5102WLMi Notebook
Acer aspire 5102wlmi vga output
Attached an lcd television to my vga output and i do not get any signal on my tv. Is there a function key to turn on vga output?
    President:
  • 1,223 Answers
Kindly u have to switch this vga output on there is toggle button
press Fn along with it press F5 button clearly marked with two monitors black and white this will enable the second output
and one more trick on the right side in the taskbar in the intel graphics accelerator icon right click and select dual display mode there as well if u have ati it is the same case see there in the task bar
pls rate me FIXYA if i fixed ur problem
Posted on Mar 03, 2009
Trouble with HDMI output on Acer Aspire D257 Netbook.
VGA Driver? Does your tv have a VGA Connection? Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
For Drivers: They won't be called VGA but either (Display, Video or Graphics Drivers)
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Apr 01, 2012 | Acer Aspire One Netbook
Can i connect my pc which is acer aspire 4720z to my LCD TV WHICH is LG22LH20R? if so which port/data cable i have to use??
The LCD TV does not have the software installed on it to integrate with the Pen drive. That is why. Pen drives are meant for input and output of data via computers with USB ports. The pieces of software required to make a computer recognize and interact with a Pen drive (or indeed any other external flash, solid state or hard disk drive based external storage devices) are USB and Storage Device Drivers built-into a computer's Operating System. Your TV does not have such drivers installed on it because it does not have an internal Storage Device to interact with external storage devices.
Your notebook can connect to the LCD TVs VGA Port by connecting a VGA Cable from the Port to the Notebooks own VGA Port -> press and hold the Fn key bottom left of the keyboard -> press the Function key at the top of the keyboard bearing the image of two monitors -> release both keys -> use the TV's remote to select Menu -> Input/Source -> PC.
Nov 15, 2011 | Acer Aspire 4720 Notebook
I have an ACER Aspire laptop that i would like to connect to my Samsung Series 5 500 tv but in the manual it only explains how to connect a PC how do i hook up my laptop to my tv?
Look for a VGA output on your laptop. You will also need a VGA cable. Also there are function keys along the top of the laptop (should have a small display icon) that you need to set to route the video signal to the external VGA connector.
Jan 13, 2011 | Samsung Televison & Video
Cannot get video to tv with vga to s-video adapter
try to use the vga output enable function key. it should be one of the "F-keys" (F5, F6...) hold the "Fn" key (generally in blue for the acer aspire 5520 series) and press a key that has a drawing resembling two monitors, but not the one that has a brightness drawing inside on of them, as it will turn off your main screen backlights. in the acer aspire 5520, it is the F5 key. look for a picture of this model's keyboard and you should see a similar key on your netbook as it is a manufacturer standard.
Feb 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
I connected my Acer Aspire 5102 to TV With a VGA to 3RCA Component but there is no signal.What to do?
Try fn and f5 or fn and f6!
I know that is wht you do with the 5315.
Hope iv helped.
Jan 17, 2010 | Acer Aspire 5102WLMi Notebook
Connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Acer Aspire 1640Z Notebook
I can't get my Acer 5610 Laptop to connect to my LG LCD TV. It just says no signal.... I am using a 15 Pin VGA Cable.
Once connected the LCD press Fn + F8 to switch the monitors. You cannot use both the screens at the same time.
If pressing Fn and F8 does not help Try other combinations of function keys with Fn
Sep 03, 2009 | Acer Aspire 5610-4648 Notebook
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
Connecting Acer laptop to secondary monitor
Have you use the Fn Key plus the Monitor Icon written on another F Key in the same color as the Fn Key?
WV
Nov 01, 2008 | Acer Aspire 5100 Notebook
Problems connecting my acer laptop with tv
Sound and picture are two seperate things unless you use an HDMI cable so lets just deal with the picture first
After you do the connection, you need to tell your laptop to present the picture to the TV.
1- On your keyboard, one of your function keys (F1, F2 etc.) will have a short cut for this as a secondary functionality. Check for the function key that has an icon on it that looks like a screen (usually it is f4 or f7). Then hit the key that activates  your secondary functions and the key you just identified. This should activate the VGA output and in most cases will also give you a configruation screen (where you can select it as a secondary display, dual display etc.)
If this short cut doesnt work, you can try this
2- Make sure VGA cable is connected on both ends. Right click your desktop on the computer and select "Properties". On the new dialog, select the last tab "Settings". Click the drop down box under "Display" and you should see the TV as the secon option, select it. Then select the check box that says "Extend my display...", click Apply and OK. This should expand your screen to the TV, you should now be able to drag windows from your laptop's screen to your TV's.
Good luck! (Instructions on option 2 are for XP, if you use Vista let me know and I will look up the terminology for that)
Oct 31, 2008 | Acer Aspire 5102WLMi Notebook
Acer Aspire 5102WLMi Notebook Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
