Question about MSI : K8N Neo4 Platinum Athlon64/S939/nForce4 Ultra/DDR400/PCI-Express/ATX Motherboard (MOT81)
Will not power on, completely dead
So I moved recently and setup the system (kn8 neo4 platinum) in its new home. Opened it up to make sure everything was still seated. Plugged everything up and nothing but a slight "electronic" noise that lasted a split second. I checked both on and reset switch functions, and jumped the power supply (volts are good) and all was ok. So im assuming its something on the board. Is it a complete loss? Can I just keep the PS jumped to power the system, or would I be asking for more trouble if its a deaper problem than just turning on?
aceltix
  • 119 Answers
SOURCE: where can i get the drivers for this mobo, audio , netcard
this is the normal non platinumK8n
http://global.msi.com.tw/index.php?func=proddesc&prod_no=249&maincat_no=1&cat2_no=171
this is the platinum edition
http://global.msi.com.tw/index.php?func=proddesc&prod_no=242&maincat_no=1
by the way...one of the greatest mainboard I ever saw and tested..
I have myself a K9A Platinum..
good luck man...and fixya:)
Posted on Feb 08, 2008
leecom72
  • 4806 Answers
SOURCE: 1long 2 short beeps, No POST/Visual display
Hi there
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue.
If you are using a PCI Express graphics card remove it and use the on-board VGA/DVI port
If it is the on-board graphics you are using clear the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted.
Good luck and thanks for using Fixya!!
Posted on Feb 18, 2009
Jay_Sav
  • 93 Answers
SOURCE: System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Posted on Mar 05, 2009
Geekman
  • 32281 Answers
SOURCE: MSI K8N --Compatible video card
Get another GForce video card a later model with at least 256Mb of memory. If you play games you might want a higher spec GForce video card.
Posted on Mar 15, 2009
  • 153 Answers
SOURCE: pc will not start
Make sure the processor is seated firmly. Also make sure that the MB connectors are securely plugged in. Looks like there is a main connector AND a 4 pin connector on this board with the 4 pin being just to the right of the ports that are on the back edge of the board.
Posted on Oct 05, 2009
Testimonial: "thanks, ive added further comments if you can think of anything further"
How do I set up my google home to my new wifi?
It appears you connect it from the phone app:
I can't establish a Wi-Fi connection If you're able to see your Wi-Fi network listed in the Google Home app during setup, but you can't connect your Google Home device to the network and complete the setup process, try these steps. Initial checklist
  1. The Google Home device is powered on and plugged into a wall outlet.
  2. Make sure you're using the correct password. Try re-entering it again.
  3. On your mobile setup device, make sure:
  4. Make sure the Google Home device is within 15-20 ft (4-6 m) from the Wi-Fi router.
  5. Has the Google Home been connected to this network before?
    • Were there any recent changes to your network?
      • Did your ISP (Internet Service Provider) upgrade or make any changes to your router/modem?
Apr 28, 2018 | Google Computers & Internet
K8n neon 4 platinum 1 audio drivers
Hello you can download the drivers here:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=XP%2032
By selecting your windows system.
Click on the sound link for download.
The file needs to be unziped, before you install the driver.
Reboot after the install is done.
Here is no drivers for windows 7.
Here are the other models:
http://www.msi.com/service/search/?kw=K8N%20Neo4%20Platinum&type=product
Good luck
Feb 16, 2013 | MSI K8N Neo Platinum Motherboard
I have recently installed windows 7 but there is no audio sound i think drivers have not been installed that is why my computer is lack of audio sound to hear a music please make a hand to me i mean h
Hello here is the homepage:
http://www.msi.com/product/mb/K8N-Neo4-Platinum--PCB-1-0-.html#/?div=Driver&os=All
Here is no sound drivers for windows 7.
If i am wrong by the mainboard model, enter the ms xxxx number here:
http://www.msi.com/service/download/
The ms number is located on the mainboard.
The solution is to buy a sound card, to add on the mainboard.
You just have to make sure, the driver is available for your windows system.
A sound card, can be bought online, or in a computershop.
As i know, MSI is not planning to make drivers, for this mainboard for windows 7.
Good luck
Feb 01, 2013 | MSI K8N Neo4/SLI Motherboard
I want complete motherboard driver
First verify that the board model is MSI K8N Neo4 Platinum/SLI. The following drivers may not work for any other board model.
There are two ways to download the drivers. First try the MSI live update utility. It will search for and automatically download the required drivers.
You can get the Live Utility from this page.
If somehow the utility does not work, go here and download the drivers manually one by one.
Please note that MSI does not provide all drivers for every OS and the board may not be compatible with newer systems.
Dec 04, 2010 | MSI K8N Neo4 Platinum/SLI Motherboard
Fan does not come on mobo & Fan on video card making a noise
There are many sensitive parts inside your CPU that can be destroyed by simply opening your box/chassis.
*If you are not confident that you can safely open the casing, then you should seek assistance from a qualified technician.
Remove the power cables before proceeding!
The first step in checking to see if your CPU fan is working is to remove the case cover, normally secured with screws at the back.
Most common chassis covers will slide out after the screws are removed.
*Make sure that you maintain contact with the metal part of the chassis to avoid causing ESD damage to your CPU/internals.
Next step, re-attach the power cable and avoid touching the metal chassis this time (there is a risk of shock) before you power on. You should see the fan moving at this point, if it is still working.
Fan not moving? You can take that small paint brush and very carefully run the brush along the fan blades to clear them of dust bunnies. This could also get your fan to run again. It is an immediate solution, but not long term.
It is more adviseable to replace the fan if it siezes or stops working.
Hope this helps.
Jun 23, 2009 | MSI K8N Neo4 Platinum/SLI Motherboard
Hi there
Feb 18, 2009 | MSI K8N Neo4/SLI Motherboard
K8N NEO4
cpu casing? What is that? To test the power supply, just use a paper clip in the ATX connector on the green wire, and the black wire next to it. Make sure everything that is hooked up to the power plugs, is unplugged. That should tell you if its the power supply.
Jan 23, 2009 | MSI K8N Neo4-F Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
Where can i get the drivers for this mobo, audio , netcard MSI K8N Neo4-F ms-7125 platinum
Feb 08, 2008 | MSI K8N Neo4-F Motherboard
Need help
u need manual for dis motherboard? MSI K8N Neo4 Platinum PCI-E
Nov 12, 2007 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
MSI : K8N Neo4 Platinum Athlon64/S939/nForce4 Ultra/DDR400/PCI-Express/ATX Motherboard (MOT81) Logo
44 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
