Question about Lexmark X5470 All-In-One InkJet Printer
It says left cartridge incorrect, its a lexmark x3350, whats up with that? how can i get it to work.
    Problem Solver:
  • 9 Answers
I'm sorry you are having problems with your Lexmark printer.
Please ensure you are using the correct cartridge.
X3350:
Black 32
Color 33
X5470
Black:28
Color: 29
If you are using the correct cartridge for your machine you can try to do the following:
Cleaning the print nozzles: (X5470)
1 Load plain paper.
2 Press Copy Mode.
3 Press .
4 Press or repeatedly until Tools appears.
5 Press .
6 Press or repeatedly until Maintenance appears.
7 Press .
8 Press or repeatedly until Clean Cartridges appears.
9 Press .
A page prints, forcing ink through the print cartridge nozzles to clean them.
10 Print the document again to verify that the print quality has improved.
11 If print quality has not improved, try cleaning the nozzles up to two more times.
Wiping the print cartridge nozzles and contacts:
1 Remove the print cartridges.
2 Dampen a clean, lint-free cloth with water.
3 Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown.
4 Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and
5 With another clean section of the cloth, repeat step 3 and step 4.
6 Let the nozzles and contacts dry completely.
7 Reinsert the print cartridges.
8 Print the document again.
9 If the print quality does not improve, clean the print nozzles. For more information, see “Cleaning the print
cartridge nozzles” on page 92.
10 Repeat step 9 up to two more times.
11 If print quality is still not satisfactory, replace the print cartridges.
If you are still getting the incorrect cartridge message it would be best to return the cartridge and exchange it for a new one.
Thanks
Catherine
Posted on Mar 11, 2009
I have an Lexmark x3350 and bought a new black ink cartridge a couple weeks ago. I was working fine till now, printer screen is showing Left cartridge incorrect. I unplugged everything, tried ...
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 22, 2011 | Lexmark X3350 All-In-One InkJet Printer
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
I've just took my ink cartridge to Walgreens where they refill ink cartridges, and Lexmarks is one of the ones they provide this service for. However, once I got home and installed them in the printer, I...
Seeing as the printer was working before you had it filled at Walgreens, I would have to say that there is a problem with the cartridge, buy a new one and if it doesn't work try to find a new Lexmark that can use this cartridge!
Mar 17, 2011 | Lexmark X3350 All-In-One InkJet Printer
I have a Lexmark X3350 and I just replaced the blank cartridge (on the left). Now it is saying Left Cartridge Incorrect. It is in there right, what else can I do?
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 16, 2010 | Lexmark X3350 All-In-One InkJet Printer
I replaced a black cartridge in my x3350 and get a cartridge incorrect
if you removed the cartridge and replaced it several times, it is most likely a defective cartridge. Return it to the store where you purchased it.
Nov 03, 2009 | Lexmark X3350 All-In-One InkJet Printer
I replaced a new lexmark 23 print cartridge in my X4530 printer.
This happens from time to time. I have bought new 22 & 23 cartridges for my Lex. x3350 before with "flawed" contacts. Either return it for refund or buy a new one. Thw next working one you get, try re filling it. I get mine refilled at Walgreens. Cost for me in Texas is $10 for black and 15 for color. I refill them 4 times before I replace with new. Saved me a ton of money.
Jul 01, 2009 | Lexmark X4530 InkJet Printer
Ink cartridge wrong
Some times new cartridges just don't work
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
QUESTION
Facing the X3350, the black ink cartridge goes on the left, the color on the right
Dec 22, 2008 | Lexmark X3350 All-In-One InkJet Printer
Lexmark x3350
Some times the new ink cartridges are defective and won't work. you should be able to go out and get a new one. but before that take the ink cartridge out and use a tissue and clean the conacts on the front and bottum that should fix it if not you will need a new cartridge.
Jul 24, 2008 | Lexmark X3350 All-In-One InkJet Printer
Right cartridge incorrect for Lexmark X3350
checked the Lexmark knowledge base for the error message "right cartridge incorrect". It came back with instructions for the X8310/8350, X7350 and X7170. Nothing for the X3350.
http://www.lexmark.com/uncomplicate/chan...
The instructions seem to be pretty much the same for all other models so maybe they'd work for your 3350. If not, there's always the technical support link. I've got an older X1150 and tech support has always helped me out
Feb 22, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Lexmark X5470 All-In-One InkJet Printer Logo
246 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
