Question about Refrigerators
My breezaire cooling unit seems to have lost it's ability to cycle off once my cellar gets to 56F....went down to 49F and keeps running. looking for causes as well as recommended service agents in the greater denver area
  • 410 Answers
Hello its Peyton again. I didn't see your last question about letting it run to protect your wine until after we had disconnected. it should be safe as long as the unit doesnt go below freezing. It shouldnt hurt the equipment at all. thanks again for using FixYa Peyton
Posted on Mar 03, 2009
WK[L] 3000 unit can not change the set temperature. It is stuck on 64 degrees. The unit continues to run and the temperature shows 55.
IVE SEN THIS ISSUE BEFORE
THE FACT THAT YOU CANT CHANGE THE SET COOL POINT ON THE UNIT BELOW 64 IS A SYMPTOM OF A DAMAGED CONTROL BOARD (SENTRY III), NOW THE UNIT CONTINUING TO COOL DOWN BELOW THE SET COOL POINT OF 64 AND GOING ALL THE WAY DOWN TO 55 IS MOST LIKELY THE RELAY.
I HAVE FIXED THIS EXACT SAME ISSUE BY REPLACING THE CONTROL BOARD AND RELAY ON THE UNIT.
Sep 23, 2014 | Breezaire WKL-3000 Wine Cellar Cooling...
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
Buy whole unit or replace motor
A PAIR OF FAN MOTOR WILL COST YOU$90 DLLRS PLUS INSTALL, ANY ONE CAN INSTALL THE FANS , UNIT WILL HAVE TO BE REMOVED FROM INSTALL, ONCE ON A TABLE DRILL OFF THE RIVETS AND REMOVE COVER, LIFT THE BLUE INSULATION COVER THAT WILL BE EXPOSED AND YOU WILL SE ALL 4 FANS TWO COLD SIDE(EVAP SIDE) TWO HTO SIDE (CONDENSER) USE A PHILLIPS SCREW DRIVER TO REMOVE FANS INSTALL THE NEW ONES AND CLOSE UNIT USING SELF TAPPING SCREWS OR 1/8 RIVETS AND A HAND HELD RIVET GUN.
Feb 23, 2012 | Breezaire WKCE 2200 Wine Cooler
Unit is not cooling. there was dust on the coils that i cleaned off. Now the unit wont cool and there is a dot next to the temperature which is 76
UNPLUG FOR 15 MINUTES AND REPLIUG UNIT IT SHOULD RESET UNIT, DOT IS A DELAY MODE FEATURE OF THE UNIT, YOUR UNIT IS NOT A WKC IT IS A WKCE1060
Jun 19, 2011 | Breezaire WKC1060 Wine Cellar Cooling Unit
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
I need a wiring diagram for a Breezaire WKE 8000 wine chiller/cooler. Does anyone know where I can download one?
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
Mar 16, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
