Question about Weber 847001 (NG) Grill
Gas emitter makes "puffing" sounds
This hybrid hgas/charcoal grills is great, but it started demonstrating trouble "starting" after six months or so. After lighting, the gas emitter in the grill makes "puffing" sounds and does not maintain a constant flame. I have to manually keep it lit until it is hot enough. I have cleaned the emitter and have a full tank, but don't know enough about the unit to troubleshoot any further. Suggestions?
Thanks
    Champion:
  • 274 Answers
You most likely have a blockage in the gas orifice or in the tube that delivers the gas to the charcoal. You have to take them apart to clean them out, not to hard to do.
Posted on Jan 12, 2010
Why southbend temp various over the grill ? set on same settings but will be hotter in spots
This uneven heating is something "grillers" have dealt with since we started cooking...the heat is higher directly over the source and gets progressively cooler as you move away.. This is more pronounced with gas or electric grill/cookers..because the heat source is in a fixed position...WITH charcoal, you can spread the coals out (if you use enough).. and get even heat over a larger area.... I have a NEW 4 burner(w/hot pad) Charbroil gas grill and a old Charbroil charcoal grill...I HAVE NEVER used the gas grill...and I grill 1-2 times a week!! ..(it was a gift/two years ago.... wanna buy it?)
May 31, 2017 | Grilling
Don't know how to use my propane, charcoal and fire box grill
Did it come with any sort of manual? That is probably the best way to start. If you haven't done it yet, hook up the propane tank to the hoses on the grill. I would say that the rack under the grill is for storing the propane tank and bags of charcoal or wood. Of course, the knobs are for turning the gas on and off. In between the left most knob and the one to it's right, there is an ignition switch type button, you press it when you have the gas turned on and with a lighter, you ignite the propane. Do NOT turn the gas all the way up before it is lit though, that is a sure way to burn some hair off or actually do some serious harm to yourself. In the charcoal section, you put maybe three inches of charcoal in the bottom of the cylinder. Use some paper or dry pine straw as extra fuel to get the charcoal started. Put a bit of lighter fluid on the charcoal then drop a match on it. I'm not too familiar with fire boxes, but from what I see, you need to use wood in the bottom of it. I can't see under the fire box, but you probably can dump the ashes out after you're finished with it. Start a fire with the wood and cook your food. If I may add a suggestion about cooking with wood, don't use nasty old rotten wood to do it. Cut some good smelling wood and let it sit for a while before you burn it. It will imbue the food with a good smell and taste. Other than that, it is up to you to learn to use your new grill. Good Luck.
Mar 30, 2013 | Grilling
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
I just bought a 18.5 in. weber and after im done cooking and close the vents the coals continue to burn much longer then my 2 previous grills.
Sue, this question/problem has been voiced a couple of times before and I'm not sure it's a problem with the grill. It's more of a problem, of how much charcoal is being used and how long it takes to grill whatever you're grilling, how many portions are being grilled and how long it takes.
My experience has been, after during numerous grilling demonstrations and cooking shows, most folks use way to much charcoal for what they're trying to grill. Charcoal is slow to heat up completely and slow to cool off and extinguish. Especially, if you're using to much charcoal. The slogan I always use when cooking with charcoal is "less is more". When you use less, throw in a couple of chunks of Western Cooking Wood. It will add a great flavor and may convince you to switch to it entirely. Also, all natural lump charcoal lights faster and burns cleaner than charcoal briquettes. It also cools off faster, when the grill is closed completely.
Give it a try, I know you'll see a difference.
Apr 13, 2011 | Weber Grilling
I have a 1 gal tank for starting charcoal. I don't
Find a local business that sells Weber grills or try the place you bought it from, and see if they have replacement parts. One thing you can try before doing that is this: Some hoses have an excess flow built-in to the hose end. If you open the valve too fast it checks it so no gas comes out. Close the valve again, wait a minute and then open it very slowly and see if that makes a difference.
May 12, 2010 | Weber Performer Grill
Using ceramic briquettes with lp gas grill
Many people enjoy using Lp/gas grills for their ease of use and efficiency. Frustrations caused by flare ups and hot spots encourage the use of a wide variety of briquettes and other products. Ceramic briquettes are most commonly used because they provide an even heating surface and last for several uses.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. "SOOC" is Copyrighted by Flickr user: Robert S. Donovan (Robert S. Donovan) under the Creative Commons Attribution license. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a05/8n/jr/should-use-briquettes-gas-grill-1.1-800X800.jpg'); }); Types
  2. Gas grills most often use ceramic briquettes, lava rocks or, more recently, ceramic tiles in order to distribute heat. Ceramic briquettes come in the traditional shape, lava rocks are similar to those used in landscaping, and tiles only differ from briquettes by shape. Traditional charcoal briquettes can be used, though they maintain several disadvantages. Use
  3. Place briquettes, tiles, or lava rocks in a solid layer on a screen between the heating element and the grill surface, making sure to leave space for air to circulate. Light the grill and check to make sure that all areas of the heating element are covered, filling any empty spaces. Advantages
  4. Ceramic briquettes, tiles and lava rocks all serve the same purpose. The advantage comes from their ability to reduce flare-ups and hot spots. They can also be used several times, minimizing set-up and making cleaning easier. Traditional charcoal briquettes are cheap and easy to find. They also provide the smoky flavor associated with traditional charcoal barbecuing. Disadvantages
  5. Ceramic briquettes, tiles, and lava rocks are not as easy to find as traditional charcoal briquettes and are more expensive. Traditional charcoal briquettes do not repel run-off from food, but rather retain it, causing hot spots and flare ups. Charcoal briquettes also need to be replaced after each use and are harder to clean up. Warnings
  6. Any additional product placed inside a lp/gas grill should not come in contact with the heating element. Doing so can cause increased stress to the grill, as well as clog vital gas ports. Always maintain a clean grill. A buildup of old briquettes can cause inadequate performance.
May 01, 2010 | Ducane 30400040 Stainless Steel Grill
Charcoal in a gas grill...Wassup with that?
Well are they lava rocks or charcoal? The Master Flame series is supposed to have lava rocks. If what you see is charcoal, remove it and replace with the lava rocks. You can order the rocks from Char-Broil's website.
Sep 06, 2009 | Char-Broil CharBroil Master Flame Gas...
Grill Chef bbq not enough heat , goes up to 400%initially and back down to 250%. Has been cleaned thoroughly. Garbage?
if you want good constant hot fire change charcoal i switched from briqutes to lump or what they call natural charcoal i use royal oak but best choice also markets it. thing is they add starch to briqutes to make them stick together and burn longer thus reducing constant heat the natural lump charcoal work great for good hot fire ill assume your grilling steaks works great on them hope this solves problem
Aug 16, 2008 | Patio Classic Barbecue Bucket Grill
Grill Blew up
Yes...........I just had my grill go up in flames as you discribed. The gas hose fitting is a crimpedconnection that connects the hose to a small male fitting. This is not properly enginered ... there should have been a brass conection there. JT
Aug 26, 2006 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Weber 847001 (NG) Grill Logo
196 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
