Question about Garden
Had to replace starter cord on 2 year old 2 stroke victa tornado motor - can't get any tension for cord to retract
  • 1 more comment
  • Anonymous Mar 28, 2009
    I have a similar problem.....the cord does not retract properly...I have tried oiling the pull cord assembly & this does help but every so often when you pull the cord it does not retract
  • Anonymous Apr 05, 2009
    The starter cord does not retract at all. The mower is only two years old. I took off the case and cannot get to the area that houses the cord and cannot fix it.
    Any suggestions>?
  • sunspotbaby6 May 19, 2009
    i need to replace the starter cord on a craftsman 550 mower
    model# 10T802 type#1095 code#B1. can anyone please tell me how to do this properly...thanx much
  • 32 Answers
SOURCE: need to buy starter pull cord --- size??
take your cord with you and get something similar in size
Posted on Jul 23, 2009
SOURCE: Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Posted on Oct 08, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I need a picture of a Victa 2 stroke carboretta -
check ebay randys engine repair
Posted on Oct 26, 2009
  • 110 Answers
SOURCE: how to replace starter cord on a victa corvette
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Posted on Nov 15, 2009
SOURCE: Victa 2 stroke mower will not start
Hi ...i have a Victa 2 stroke mower, just replaced plug and replaced aircleaner, engin still won't start. Can you help me
Thank You
Ivan
Posted on Sep 14, 2010
Need a user manual and product parts list please
These are available on the internet. Look up Briggs and Stratton motors, you will find the info you need. Sorry , but I am a bit strapped for time to go looking for you.
Mar 13, 2016 | Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
On my Baumr-AG Tornado 650EX 4-stroke lawn mower my starter cord will not retract
There is a spring under the dog ear plate it's probably broke there's a hook on one in of the spring that hooks on to the housing and and the others end hooks to the starter pull it's self take bolt out of center of pull start and take a look be easy the spring sometime likes to fly out its not a typical spring per say it's a coil spring wound up
Jan 06, 2015 | Garden
How to change cord victa corvette 160cc 2stroke electronic ignition
On assuming its fitted with a victa 2 stroke engine in which case unscrew the 3 cross head screws on the top plastic cover and remove it. You should then see the top of the engine and the recoil starter. Undo and remove the 3 bolts holding the starter to the engine. Remove the starter housing gently as there will be a large o ring under the stater. Once the starter is off you can undo the centre bolt and remove the recoil pulley and spring. When refitting starter smear a little oil on the large o ring to stop it from being damaged
Oct 11, 2014 | Garden
Winder not going back in
Hi pete are you talking about the starter cord or the cutting cord. If it's the starter try and put some lube spray where the spring for the starter is and it should free up. If it's the cutting cord then you have wound it on wrong or not tight enough. Start it again and if this doesn't help let me know via the reply section
Dec 13, 2013 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
How to replace starting cord in Victa motor mower
or the spring has come out the locating thing inside ... put more tension on it and repeat the assembley.
Mar 01, 2009 | Garden
Victa lawnmower
how do you replace the zip cord on a victa tornado last years model
Oct 12, 2008 | Garden
Garden Logo
829 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
