Question about Dell 1900FPSE 19" LCD Monitor
I need to find a replacement board fot the High Voltage section in a DELL 1900FP UltraSharp display. Transformer TM-511R (1 of 2) cooked.
  • Anonymous May 05, 2009
    Exact problem
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Ritchard, You may want to try this site: www.slelectronics.net/nec-lcd/monpart.htm will get you to pages with list of other manufacturerers other than just NEC. I'm louie12fix on fixya or lmistyrel @aol. com. Note: Take pictures of how everything go's back together before you take it apart. The board with the Transformers on it and connects to the 4 plugs from the sides of the LCD/FPD is called an INVERTER board. It takes 12v-15v and turns it iinto something like 1200v-1800v and of an AC nature running at a frequency> 30khz. BYE.
Posted on Mar 03, 2009
Dell 1900FP flat panel color monitor the on screen display wont go off
try to remove power lead for a minute or two and put it back in. Should be better.
Apr 07, 2014 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Dell 1900 fp monitor driver
Go to GOOGLE and type DRIVERS for your exact product and model of monitor, which will hopefully give you the correct drivers to download. Softonic would be one place to look. CNET would be another.
Sep 19, 2012 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
MY DELL 1900FP WILL NOT POWER ON
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Apr 07, 2011 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Monitor light blinks no picture
(Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....) If you have guts.. then do the following steps..
You said your monitor will blink but no picture display... well, there are possible reasons why this problem occur..
1. Open the back cover of your monitor..Check the power supply section for possible loose connections and blown capacitors.. Resolder any loose terminal connection on the pcb. Check for any blown capacitor, replace the capacitor with exact value, and also replace any bulging capacitor..If you have successfully replace the parts you can try to turn it on and connect the vga cable in it to the video card of your computer. Turn on also the cpu, if the monitor led turn green and the display came out..that fixed it.
2. In case you have successfully repaired the power supply section and the led of the monitor stays green.. then the problem will be in the inverter board section....Turn off your monitor... open the back cover...on the inverter board section.. check and replaced burnt or overheating high voltage transformer..if one or more of this overheats, it is enough to affect the supply current from the power supply section and that may cause to blow your capacitor...If the ballast transformer is working fine the last thing to check is the backlight inverter (the light that illuminate causing display in your monitor) Replace any busted lamp.. that should fix the black screen on your monitor. ..
If you find this information very useful..please be kind to rate this solution and vote for this on the help below...thanks..
Much appreciated if you rate this help...thanks...
Jun 02, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My Dell 1905fp Ultrasharp was coming on intermittently for a little bit and then it would not power up at all.
You said your monitor will be on for little bit and then would not power up anymore... there are two possible reasons why this problem occur..
1. You need to check if the high voltage ballast transformer of your backlight inverter is about to be burned... the transformer is overheating..that's why you experience the monitor working for a couple of minutes and then it will shut off until the transformer cool down again and then it will be ready to work again...
2. You need to check the power supply section for possible loose connections and blown capacitors.. the ballast transformer has direct effect on power supply section.. when there is overheating transformer,,, the supply current from the power supply section becomes unstable.. and will not be able to supply the remaining good working ballast transformer.
In case you do not know, the ballast transformer generates high voltage for the backlight inverter to work..The backlight inverter is the light source that is responsible for the image display of your screen...If the ballast transformer is not working or if the backlight is busted then the only thing that you will see in your screen is black....
May 24, 2010 | Dell UltraSharp 1905FP LCD Monitor
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900FP
you can push every lamp from 19inch monitor who have same jack for conector{i work that, i have dell1900fp}!!!sorry for eng.good luck
Sep 28, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
No power dell 1900fp silver blank screen power ??? help!!
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to support.dell.com
Jun 03, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Computers & Internet Logo
355 people viewed this question
Alun Cox
