Question about Refrigerators
HAVE A TRAULSEN M#UL3SBS-X0010 HAVE PSI OF 16 LOW SIDE AND HIGH SIDE OF 325 TO 350 IS THIS RESTRICTION
  • 400 Answers
High side can be caused by restricted or blocked condenser coil, or fan not working. Or air in the system.
Posted on Mar 05, 2009
What is the gas pressure on both compressors on subzero 321
The pressure of the refrigerant in the systems vary depending on the temperature of the refrigerant gas and the type of gas used. So this is a question that can't be answered without a lot of additional information.
Mar 02, 2015 | Refrigerators
I have a Traulsen walk threw refrigerator Im getting a high pressure of 600 and a low pressure of 80 and cant get it to cool down, do I need to pull the system down or try something else
Hi side is too high. Look for a condenser plugged with refrigerant oil or the fan not spinning up to speed. If it was serviced recently there could be air in the system or a flake of copper oxide clogging the orifice tubes in the evap.
Jan 13, 2014 | Traulsen Refrigerators
I work for a schools district and a problem with our walk in. cooler is our condenser fan wasnt workin, dirty condenser coil. After I fixed those problems, my compressor is coming off on low pressure. It...
@50/300 I assume it's a med. temp R-22 pump down walk in. Head pressure sounds a little high, probably been overcharged to compensate for a restriction in the metering device (or malfunctioning TXV). Check the solenoid (if pump down), metering device, and filter driers first. If that fails, lineset restriction or non-condensables/water in the charge would be next on my list.
Sep 29, 2011 | Heating & Cooling
Low side pressure specs for 2003 silverado2500hd
Ambient Air Temperature
Relative Humidity
Service Port Pressure
Maximum Left Center Discharge Air Temperature
Low Side
High Side
13-16°C (55-65°F)
0-100%
150-246 kPa (22-36 psi)
730-1190 kPa (106-173 psi)
12°C (54°F)
19-24°C (66-75°F)
Below 40%
150-280 kPa (22-41 psi)
900-1390 kPa (131-202 psi)
14°C (57°F)
Above 40%
179-137 kPa (26-46 psi)
990-1500 kPa (144-218 psi)
16°C (61°F)
25-29°C (76-85°F)
Below 35%
218-328 kPa (32-48 psi)
1240-1640 kPa (180-238 psi)
17°C (63°F)
35-60%
236-342 kPa (34-50 psi)
1290-1680 kPa (187-244 psi)
18°C (64°F)
Above 60%
250-365 kPa (36-53 psi)
1340-1760 kPa (194-255 psi)
20°C (68°F)
30-35°C (86-95°F)
Below 30%
266-386 kPa (39-56 psi)
1500-1940 kPa (218-282 psi)
21°C (70°F)
30-50%
280-397 kPa (41-58 psi)
1540-1990 kPa (224-289 psi)
22°C (72°F)
Above 50%
300-430 kPa (44-62 psi)
1600-2070 kPa (232-300 psi)
24°C (75°F)
36-41°C (96-105°F)
Below 20%
328-439 kPa (48-64 psi)
1810-2240 kPa (263-325 psi)
25°C (77°F)
20-40%
337-457 kPa (49-66 psi)
1840-2290 kPa (267-332 psi)
26°C (79°F)
Above 40%
355-474 kPa (52-69 psi)
1890-2340 kPa (274-340 psi)
27°C (81°F)
42-46°C (106-115°F)
Below 20%
391-491 kPa (57-71 psi)
2130-2500 kPa (309-363 psi)
29°C (84°F)
Above 20%
397-508 kPa (58-74 psi)
2160-2550 kPa (313-370 psi)
30°C (86°F)
47-49°C (116-120°F)
Below 30%
451-552 kPa (65-80 psi)
2420-2790 kPa (351-405 psi)
33°C (92°F)
Jul 10, 2011 | 2003 Chevrolet Silverado 2500HD
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
What is a/c pressure on a 1999 kenworth when fully charged with a c 15 cat 550 hp tx KIETH.
low side psi will run about 30 psi, hi side pressure will go as high as 350 psi then the pressure switch will kick the engine fan on then drop psi down to 120-150 psi
Jan 15, 2010 | Q-Logic QLE4060C-CK Network Adapter
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 | Freezers
Restriction
The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
