Question about Emerson MW8102SS 1100 Watts Microwave Oven
Metallic-like cardboard insert inside microwave is crumbling???
While cleaning the interior of the Emerson MW8115SS my wife pushed against the cardboard/metallic/plastic insert on the right-hand side of the interior of the microwave - this caused the brittle material to fracture and create an indention, tried to slide a butter knife behind the insert in an effort to push the indention back outward, but the entire insert is now startin to crumble to pieces... My question is this: Is it safe to use the microwave without this piece present or fully intact and if not where can a replacement piece be obtained for this particular model?
I can send pictures of the damaged plate if my description is too vague...
  • stephanie221 Apr 13, 2009
    Cracked "splattershield" in microwave..is it still safe to use even though it's cracked?
    President:
  • 2,992 Answers
That piece is called the waveguide cover. Emerson calls it a spatter shield. Behind it is the hole where the microwaves enter the oven. Its job is to prevent food spatters from getting into the microwave source, and it's not a good idea to run the oven without it.
The cover is usually held in place by a plastic rivet that pulls out. I couldn't find the part number for the cover used in your model. But here is a link to a parts place that has several covers available:
http://www.a-1catalog.com/wavandstirco.html
If one of the covers shown looks like yours you can order it. Another possibility is to contact Emerson at 800-695-0098. This is the number they give to locate authorized servicers near you, and you might be able to order a replacement cover through them.
Hope this has helped. If so, please take a moment to rate the solution. Thanks for asking here!
Posted on Mar 03, 2009
    Problem Solver:
  • 11 Answers
The material your wife destroyed is actually mica, basically, a flake of stone (yes, stone). It's there just to protect the magnetron form dirt. There is no need to buy a original replacement. Look for mica sheets, draw a piece just the same size and screw it the place of the damaged one. I will post a URL here from where I get my mica. I know you probably can't read what says there but you get the point: it's a cheap, fire resistant insulator that can be bought without that "original part" tag that makes it a lot more expensive. That piece I bought is not even $5 worth.
http://www.leiritronica.com/linhabranca/product_info.php?products_id=2587
Do be careful not to tighten the mica back too hard: it might flake. Drill instead of punching any holes.
Posted on Mar 11, 2009
Cardboard inside microwave has got a hole is it safe to still use or where can i buy a replacement one.
Posted on Jan 30, 2011
    New Friend:
  • 21 Answers
The part with the hole is stopping vapours and worse still fat drops getting into the waveguide. The fat drops absorb microwaves and casn get hot enough to catch fire. You can operate the microwave without it, but only if nothing goes back up the waveguide passage to the magnetron. It may be plastic of a special type, transparent to microwaves, or it might overheat. It used to be mica, and you can still use it. Get a sheet of it from microwave parts stores, or some electronics parts stores have it. A good place is WES Components at Ashfield in Sydney.. As a previous answer said, just cut it to size and attach it.
Posted on Feb 26, 2016
My metal piece has started on fire more than twice so I took it out, I still use the oven. Have not found any health risks online yet.
Posted on Aug 24, 2014
Model:lmv1680ds
From the description it is the turntable motor, the solution! must be replaced.
Apr 07, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
My emerson microwave #mw8999rd shoots out fire from a silver piece of cardboard thats on the righthand inside of my microwave oven. whats with that?
There is electrical problem in your microwave heating circuit. This is a fire hazard and you should stop using this microwave and unplug from the outlet. This is not something you can fix and the fuse does not protect your system anymore. The best choice is to purchase a new one and throw this away.
Dec 06, 2011 | Emerson Microwave Ovens
MY EMERSON MICROWAVE WILL NOT START. THE DIGITAL DISPLAY AND INSIDE LIGHT IS ON .
That's probably a bad top or bottom (not center) door switch, or one of the switches' mounts is bad.
See my help file on door switches.
Jul 08, 2011 | Emerson Fans Emerson MW8115SS Microwave...
The fan and light com on when the door is open and the carousel turns. When you close the door everything stops.
Check the door interlock switches, you may have a faulty switch or a blown fuse inside the microwave.
Dec 31, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Microwave stopped working during heating process....timier works but does not make that microwave sound
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Model mw8115ss suffix a Emerson Microwave not working
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Aug 03, 2008 | Emerson Fans Emerson MW8115SS Microwave...
Emerson MW8102SS 1100 Watts Microwave Oven Logo
10,491 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
