Question about Hobart A200 Stand Mixer
Hobart A200 Torque in First Gear Problem
Hello. I have a Hobart A200 Serial# 1027912 Spec#3943. My kitchen staff informed me that the torque in first gear has been weakening over the last couple of months. Since this seemed like it could be a brush problem in the motor, I cleaned the copper and replaced the brushes. Seems to have worked.....but only for about a week and now its getting the same type of problem. This does occur when they are making bread dough and I have asked that they not overload the mixer but they have reassured me they haven't. I actually DO believe them. Could there be any other possible reasons to explore? Also, I did go to the hobart site for the part lists, but did not find anything that has the same motor configuration as mine. Any recommendations?
Thanks a million.
Sheaghan
  • sheaghan Mar 04, 2009
    Problem was broken motor shaft spring, and broken key in first gear.
  • 135 Answers
Remove please. ricardok45
Posted on Mar 17, 2009
A200, 1st gear had no torque(I could stop by hand). Found & replaced key on low speed gear. It sheared it again. It is just shearing it on the flat gear part, not the bevel gear part. I'm thinking it...
I have had my Kitchen Aid since 2003 and never had this problem. If this has happened to you more than once, I would call Kitchen Aid and explain the issue to them. My sister had an Issue with her new Kitchen Aid and they had her bring it for service and they replaced it with a NEW mixer. Kitchen Aid is very good with brand accountability.
Mar 01, 2014 | Hobart Food Mixers
How to change hobart a200 motor bearings
Do not heat up you have to strip the gear box but not all take the top gears off but look what you are doing its got to go back the same way or it won't work you have to take the worm gear off and then you can take it out from the back but if you can't do it get in touch with **** at x bakery in Haywood and ill sort it for you hope this helps it is a big job sorry
Jan 06, 2013 | Hobart A200 Stand Mixer
I hAVE A HOBART 200T FIRST AND THIRD GEAR WORK FINE BUT SECOND GEAR DOES NOT SEEM TO GRAB WITH ANY TORQUE. WHAT MIGHT BE THE PROBLEM?
I would say without looking at it a key is sheared or gear teeth are worn on the gear.usually its a sheared key,however if the mixer is older they use a dive key assembly which you would have to replace the shaft.I'm a hobart tech and repair these mixers often,any ? let me know.What is the ml # on the data plate?
Nov 13, 2009 | Hobart A200 Stand Mixer
Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here: http://www.primasupply.com/images/hobarta200.pdf
You may be overloading the unit. Hope this helps.
Oct 13, 2009 | Hobart A200 Stand Mixer
Age of my a-200 mixer
if it has a spec.# instead of a ml.#it would have to be at least 25-30 yrs. old
Jul 04, 2009 | Hobart A200 Stand Mixer
My 20 qt. mixer has no power in speed #1.
Hi All. Since the original poster has not responded to my request for ML and spec. #'s, I'll offer a solution based on a spec.# 3943 for anyone with the same problem. This is an older model A200 with a solid aluminum gearshift lever.
Stop using the mixer!!!
The slow speed gear (1st. gear) is engaged by a "diving key". Over time this key can wear to the point of failure, or break entirely and will no longer engage. This failure only affects the first gear, allowing the second and third gears to function properly. If you can stop the mixer attachment by hand while in 1st. gear, then you have the above problem. The unit must be serviced. If the key has been sheared there is the potential for a broken piece of this key to get into the trans. grease and cause further damage to the mixer. For a Hobart Tech., this is relatively easy to repair as a minimum number of parts need to be removed in order to expose the diving key.
Call your local Hobart office to schedule a repair. If you've never done any repairs on this model, do not tackle this project by yourself. I you have some experience with this model goto the hobartservice.com website, register for free and then download the parts list. Ensure that you have the list for the 3493 spec.
If anyone has been assisted by this solution, please rate it. ricardok45
Mar 17, 2009 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart a200 first gear not working
Sounds like the key is sheared on the gear.
Jun 05, 2008 | Food Mixers
Hobart A200 Stand Mixer Logo
265 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
