Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Connecting the wires to my sub
I have a L7 solo baric i think i kno what im doin but there if for stops to hook up the wires 2 on the top positive and negitive and 2 on the bottom same thing. do i run the wires from the top of the sub to the outlet on the box and conjoin the 2 at the bottom.
    Problem Solver:
  • 18 Answers
At 4 ohms you go from positive with the dot to the negitive with no dot and then conect the other two together and that is for 4 ohms. For 2ohms positive with dot to negitive with a dot than connect the other two together. try that shut down everything befor you start working on it so you dont blow fuses on amp or deck or under the hood. try one than turn it up see how it sounds than try the other way to see what sounds best.Contact local dealer if you are still haveing problems.If not rock out and crank that bass .
Posted on Mar 03, 2009
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
I have 2 12
To be on the safe side without further information I would hook the two subs up in series leaving you with an 8 ohm load.
Nov 12, 2012 | Kicker Solo-Baric L7 12'' Car Speaker
I have one solo baric hooked up in a 4 ohm series to a 1000 watt kenwood amp that I've tried hooked up normal and bridged at 4 ohm. When I turn it up the sub cuts out. I've looked up a bunch of...
hello, first i would find out what ohm your sub is cause you may think your setting it up for 4 ohm you may be going 2 ohm or 8 ohm. here is the link to for wiring solo baric. http://kicker.com/wiring_diagrams
Aug 24, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Cant get the bass i want.
Try checking the specs on the amp. It might not be able to drive a 2ohm load. just a suggestion.
Mar 31, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My solo kicker isnt performing right
do both voicecoils work? try one at a time...then if they do....get a piece of speaker wire about a foot long...connect the positive to the positive and the negative to the negative...then hook the wire from the amp up to one voicecoil....
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofers
sell me the subs it would be better
Oct 29, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solo-baric L7
ok here is a real pdf manual from kicker and please rate me
www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf
Jan 21, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
88 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
