Question about Zenith D61W25 61" Rear Projection Television
Not sure, but looks like blue and red shadows around words on the screen
Put new vertical ic in its short 6 inches on right and left side but do have a full vertical how can i adjust to fill the whole horizantal plus convergence is off didnt know if it was off because vertical ic not tuned in.
  • townsendbenj Mar 03, 2009
    how do I go into service mode to adjust virtical ic I have a zeinth mode d61w25
    i had no picture at all untill i installed vertical ic. picture came up it was sort on both sides horizataly and out of convergents mode to tv zeinth d61w25 realy need to know how to get into the service mode to tune in vertical ic i have no mannual
  • 2,326 Answers
What was the problem before replacing the vertical IC?
If the image looks like a 3D, then the convergence ICs will need to be replace. The parts you need are STK 392-110.
Posted on Mar 03, 2009
  • Jaime Hernandez Mar 03, 2009
    You can buy the parts from this website. I would suggest that before buying the ICs to check for any low value resistors nearby the ICs for open conditions and double check the correct ICs markings.
    Genius:
  • 1,011 Answers
Sir,
Go to the service mode and adjust it. Plz tell me ur brand name and model no. check with manual.
thanks good luck
I have a 37in. vizio flat screen. It has a black shadow in the left center of the screen. It's there at all times.It's about 7in.x 3/4in.it runs vertical.any ideas?
wish the news was better for you, the convergence chip or the color engine has faulted and burned the screen This will be an expensive repair unless it has extended warranty
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Vizio L37 Television
Red shift to left with curve at bottom
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Nov 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Red shadow around every image
call up the menu and look to see if words have red or 3d effect---if this is so, suspect you have a convergence problem; the set should also have a option for adjusting the convergence---some just give you a cross in the middle of the screen---if red or blue will not adjust either up/down--left/right you have a bad convergence IC----The Hitachi sets all use two IC's and Usually this repair can be done in your home----I do a lot of them here in the San Diego area where I live----have done over a hundred in the last year on all brands of sets. If you know someone who knows how to solder etc, you can (get me model number) buy both the convergence IC's on Ebay for under 15 dollars plus shipping; some internet places offer a kit with the IC and whatever other parts might be needed; usually this is a waste as most of the time only the IC's and maybe one or two resistors around them are gone.
If you need more direct help my email is: etower.766@netzero.net
I do this here for free so if I have helped you give me a vote here.
Aug 18, 2009 | Toshiba 55H70 55" Rear Projection...
50 inch hitachi tv, shadow behind writing and crooked screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Sony KP-53N77
Hi, you have a convergence problem, the IC`s and possibly a few precision resistors feeding the IC`s will have to be replaced, not an easy job if you haven`t done it before. If you are very proficient at solder work and can use a volt meter to check the resistors you can do the job but it isn`t easy for a lay-person, If you have more questions e-mail me back, good luck, BMW Rider
Dec 30, 2007 | Sony KP-53S65 53" Rear Projection...
Al, bring up your convergence grid (look in menu for it) and I think you`ll find that the set is out of convergence, if you can adjust the red up & down and the blue up & down your ok, if they won`t move in one or both directions the convergence IC`s will have to be changed out, hope this helps, BMW Rider
Dec 12, 2007 | Zenith D61W25 61" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Zenith D61W25 61" Rear Projection Television Logo
43 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
