FixYa.com
Tags:
D-Link 802.11g Wireless Router WBR-1310
Strange Problem
By Cornish - usenet poster
I have a D-Link WBR-1310 Wireless Router
I am able to connect to the internet throughout the whole day but I am
unable to connect to the internet in the morning after a few hours on
inactivity. I am able to connect to the internet if the cable goes from
the modem to the computer's nic card. I can after a few seconds
connected from the modem to the nic card and than transfer the cable
from the modem to router and than put back the cable from the router to
the nic card, it works fine.
Is there a setting that I am forgetting to change so the router does not
do this because it will be a pain to do this every single day? I had to
do this for the 3 mornings I had this router.
Thanks
Dan
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Thanks for Trying (70)
Rachel007
Rachel007 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is usually a sign of a bad router, when they need to be reset
periodically.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
What did your ISP do after you contacted them. Did the replace the
modem, fixed
the modem from their end, have a tech come to your place to fix it?
Was your modem bought or rented?
Thanks
Dan
Solution #3
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Before you scrap the router, have your ISP check your modem for resets. My
network was experiencing the same symptoms. Two routers later, I called the
cable company and they reported my 6 year old Toshiba was resetting 300
times a day according to their logs.
Solution #4
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Bad router as in your particular router is no longer totally reliable.
This does not mean that another router of the exact same model would
necessarily have the same problem.
However, my one-year failure rate with the low cost routers has been
terrible, I've gone through one to two dozen since I started doing this
in the late 1990's. I've had more problems with Linksys than with
D-Link, and while I used to recommend Linksys, I no longer am able to do
so. I see both failures "out of the box", and also what is more
troubling is failures that develop after 3 to 12 months. These are not
"hard failures" the routers work, superficially. But they "lock
up" and need to be reset periodically (anywhere from every few hours to
every few days). If a router can't work reliably for weeks at a time
without locking up and needing to be reset, it has a problem. And this
kind of unreliability is especially unacceptable if you have Internet
phone service (as we do).
Solution #5
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
just to be sure, you said a bad router like a bad batch or bad router
like router series is crap and get a different type?
Thanks
Dan
Can you Help with these Wireless Adapters problems?
D-Link 802.11g Wireless Router WBR-1310...
I am having trouble switching
I am having trouble switching... Answer This...
wireless connection problem. ...
Hello, just purchased wbr-1310... Answer This...
wbr-1310/verizon um150 usb...
I had a wireless isp that... Answer This...
can not get wireless router to...
I recently got a D-Link... Answer This...
D-link WBR-1310
My router is fed through a... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
