Question about HP LaserJet 4 plus Printer
HP Laser 4 Plus Not printing information
The printer is only printing one line which appears to be a font. (Looks like: AQKM:COMMEOU: IQ!MasesKeu!5AQKM1SEU1QAGEQSOUECU=OGGAQKM1SEU1QAEQSOUECU=AUUOAQKM1
I have tried everything to get it to print correctly. Can anyone help tell me what I might try to correct this. Thanks in advance
Try deleting, then reinstalling driver. When prompted if you want to replace the current driver? select "yes". If the garbled print continues, your formatter board is shot, therefore your printer is dead.
Posted on Mar 03, 2009
L7157 HP Laser Jet P2055
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
May 31, 2012 | HP LaserJet P2055d Printer
HP Officejet 6500A Plus How do I increase the font size when I print? It is too small. Thank you!
To increase the font size of your document, there should be an option called font. Here, you can change the font size, style etc. To give you more information on this, please mention the software you are using like MS Word, MS Excel, adobe reader etc.
Aug 31, 2011 | HP Officejet 6500 Wireless All-in-One...
My hp laserjet 4 plus tells me i'm out of memory
Try this:
20 MEM OVERFLOW
20 INSUFFICIENT
MEMORY
Indicates a memory overflow. Too much data is being sent
to the printer and the printer has run out of memory.
Pressing the [Continue]* key causes the printer to print only
the information it received. If the error persists, it may be
necessary to simplify the print job (such as fewer fonts and
less graphics information), or have the customer purchase
additional memory.
Jan 28, 2011 | HP LaserJet 4 plus Printer
Font size on printed copis different than shown on incoming email
Just maybe it is the size of the original e-mail and your monitor makes it appear larger. The way  that I do it is to copy and past the email into a word processor,like WORD, then set the type font to the size that I want before printing, then print from that file
Feb 23, 2009 | Brother HL-2040 Laser Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP Laser Jer 4 M plus
How is the machine connected? try changing the data cable if this doesn't work then shutdown your computer while the machine is on and reboot as if it is connected via LPT port some systems like to have the printer on before the computer.
Try this and I hope it helps if it doesn't then you might have a faulty print formatter board.
Thanks J
Nov 20, 2007 | HP LaserJet 4 plus Printer
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
Hp 1610 and 1018
Are you printing from MS Word? What software package are you using? Each printer is different and some require software settings.
Jun 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP LaserJet 4 plus Printer Logo
183 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
