Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Mitsubishi Diamond Series T.V.
When we turn on the television we can still see the picture but the color is off, its a blueish yellow whitish color.
Any advice would be great!
  • stockfam3 Mar 03, 2009
    Mitsubishi WS-55907 55 in. Rear Projection...
    Sorry, but this is the ACTUAL tv I have
    Novelist:
  • 159 Answers
When a tv (Rear proyection) shows this coloration is the meanning that the red color is not there (the red color is generated by a red CRT). Now it can be really bad not having the tube working but before conclution make sure of this: (and if the red color gets back then the tube is ok)
  • is this condition the same in all inputs? or the picture looks ok with a different video source (VCR, DVD other)
  • are the menu letters same as the picture looks or are they fine?
If we cannot see any red color back with this testing, still chances that a technician find an electronic problem that make the tube to be off. so don't rush conclusions and get to the end to save the tv with out replacing the red tube, but if all was done and nothing then the tv needs the tube replacing.
Posted on Apr 14, 2009
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
Color convergence is off
Please chech degausing coil around crt from inside
Jun 13, 2009 | Televison & Video
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
851 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
