Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Removing the front panel
I need to know how to remove the front panel on a maytag mlg2000aww stackable (neptune.)
Imm trying to find out why the yub is not spinning during the spin cycle. I was told there was a few internal switches under and a control board under the tub that i could check.
Tom
  • Anonymous May 01, 2009
    the washing machine does not go into the spin cycle
  • 3 Answers
SOURCE: Maytag Neptune mlg2000aww
SOUNDS LIKE SOMETHING STUCK IN PUMP
Posted on Oct 24, 2007
Lumpy816
  • 246 Answers
SOURCE: Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Posted on Jun 13, 2008
SOURCE: Neptune stackable washer...
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
  • 153 Answers
SOURCE: maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Posted on Mar 05, 2010
Locate thermal fuse on maytag neptune dryer model # mlg2000aww
The thermal fuse is located on the front cover over the blower wheel housing in the front of the dryer, the part # is 33001762,good luck
Aug 24, 2015 | Maytag Dryers
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Hi! How do you replace a water valve(part#22002437) on a Maytag Neptune Stack? I know how to do it on a washer only, but how do I get to it on a stack Model# MLG2000aww?
wow it's quite a job you need to disassamble the control panel area between the washer and dryer,take off the washer front panel,then reach in the back of the inside of washer to remove and install new valve and also get to the back so ya can remove and reinstall the hoses from the valve.
Wish you well i've have a few busted knuckles when doing that repair
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag stackable washer/dryer and I need to change the water temperature switch. Does anyone know how to go about doing this? I already have the part.
you will need to remove the front panel screws which will allow you to remove the end caps off the front panel after removing the control knobs,then you can replace the temp switch by removing the screws off the controls main body
Mar 07, 2010 | Maytag LSE7806A Top Load Stacked...
The clothes are coming out soaking wet.
just cause pump moves doesnt mean its working
Jun 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
122 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
