Question about American Standard 1583.470 Universal Drain, White
I need a manual of instructions for instalation of this product .
American Standard 1583.470. I need installation instructions.
  • Anonymous Mar 03, 2009
    The installation instructions or specifications that show how the links of the innards of the drain mechanism is what I need. The drain mechanism is a complex series of links and a spring mostly made of brass which have pivot points, adjustments and a cam to open and close the drain. The one link that hooks to the spring does not secure very well and disconnects. After removing and reconnecting the link, re-insert the mechanism is a difficult task, yet with all of the available adjustments, it is still a hit and miss shot for the mechanism to work properly. A diagram is absolutely necessary to assemble the mechanism for it to work.
  • Ron Dowling Mar 03, 2009
    The installation instructions or specifications for an American Standard Drain Kit Model #1583.470.020 that show how the links
  • 10,865 Answers
You will need plumbers putty and a plumber's drain tool. Put a ring of putty around the piece that will be on the inside of the tub to seal it. Then insert it through the hole making sure the rubber gasket is on the bottom side of the tub and tighten it down.
Posted on Mar 03, 2009
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
Need user manual
If the installation instructions is what you need you can get a PDF of that on Menards.com Type the pmfw432r8 in their search and scroll down to below the description info and you'll see links to a product spec sheet and installation sheet.
Feb 19, 2014 | Computers & Internet
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
Need instalation instructions
Installation instructions as a number of other resources are available here:
http://www.americanstandard-us.com/products/productDetail.aspx?id=1897
Scroll down to the listings near the bottom of the page.
Mar 16, 2011 | American Standard Traditional Champion4...
NOT a problem--preventive maintenance is my goal. I kept my Payne heat pump (installed in 1985) humming nicely until this January. I only replaced it because of cost/efficiency issues ($$$) every summer....
By code, whoeve installed this brand new unit should
have left the manual with it. Check the electrical
control box or the fan compartment to see if a manual
is not in there
Feb 13, 2010 | American Standard WCZ036F Air Conditioner
Remove from basin and install in another?
Go to American Standard website they have detailed instructions
Nov 14, 2009 | American Standard 7471.732.002 Hampton...
I need the installations for a American Standard
I had a similar problem where the Drain-Kit that I ordered was missing a part. After contacting American Standard and requesting a schematic. I realized that the missing part was the rocker assembly with stopper. I have a PDF of the schematic that I can send you if you still need it. Let me know. The alternative is to contact American Standard directly between 8am and 6pm Eastern and request the information. The phone number is (800) 442-1902 Option 3 then 1 then 2. Tell the person that you need the installation instructions for a 1583.470.xxx universal bath drain.
Mar 03, 2009 | American Standard Plumbing
How do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Jan 06, 2009 | American Standard Kitchen Faucet 6310 020...
American standard whirlpool tub #2425
Here is the link to installation instructions:
American Standard #2425
The information you need is on page #7.
Hope this helps!
Oct 24, 2008 | Home
American Standard 1583.470 Universal Drain, White Logo
260 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
