Question about Samsung Digimax A40 Digital Camera
Format error I have a Samsung digimax A40 camera. I 've just purchased a Lexar 4gb SDHC card. When I've tried to format the card for use, the screen comes up initially with "card error", then a screen to format - yes/no. When I press on yes, it takes a few moments and then comes up with Format Error, and turns itself off. Any suggestions on how to overcome this? We are heading away on holiday soon and wanted a bigger sd card as I currently only have a 256mb card in it. Thanks, Tracey.
    Problem Solver:
  • 18 Answers
I don't believe the camera can handle a card of that size. I believe the camera only supports up to 512MB cards, anything above that is not guaranteed.
Samsung Specs
Posted on Mar 03, 2009
  • 408 Answers
The reason why is because that particular camera does not support memory cards that big.  Samsung only guarantees compatability up to 512MB, but the max I have ever heard working is 1GB.  If you do buy one, make sure it is a sandisk card as these have been tested and guaranteed to work in that camera.  Lexar may also work, but for sure 4GB is to big and is unsupported.  Hope it helps.  Please dont forget to rate!
Is 4gb SDHC card compatible with Samsung A50 camera,will not format,says card error
The A50 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Oct 20, 2012 | Samsung Digimax A50 Digital Camera
Memory card after formatting, say check card (samsung camera)
Probably, especially if your card is a 4GB or larger SDHC card, then it's definitely the wrong card. The older Digimax S800 camera can only use standard SD cards (2GB or less). Fortunately, these are very inexpensive these days, and may be found on Amazon if your local store no longer carries them.For others reading this experiencing similar problems, please see this article.
Nov 27, 2011 | PNY 4GB Secure Digital High Capacity...
HOW DO I FORMAT MY LEXAR SDHC? i PUT IT IN MY CAMERA AND IT SAYS TO FORMAT. I SAY CONTINUE AND THEN IT GOES INTO THIS LOOP. ''NEEDS TO BE FORMATTED.''
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 02, 2011 | Cameras
I put a new sd card in my camera and it says check sd card. It wont let me take pictures what does that mean
Your model camera can only use up to a 2GB standard SD cards, and not 4GB or higher SDHC cards. There are several other possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before the SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 02, 2011 | Samsung Digimax D53 Digital Camera
Unable to get a 4g SD card to work in this camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 23, 2010 | Samsung Digimax D53 Digital Camera
I purchased a 8gig sd card and tried to put it in
The camera only supports SD memory (limit 2GB), not SDHC (4GB and more). The manual claims up to 1GB guaranteed, though the camera recognizes my 2GB card card.
Nov 29, 2009 | Samsung Digimax D53 Digital Camera
I have a NV10, it will not format the lexar 4GB SDHC memory card I bought, all it says is format error
The NV10 will not accept SDHC type memory cards. The largest card you will find it takes is a 2GB card of the SD type (not SDHC). The camera is not SDHC compliant, unfortunately. If you can return the 4GB Lexar, swap it for a 2GB of the non-SDHC variety. If this answers your question fully, please rate the solution accordingly. Thanks
Nov 07, 2009 | Samsung NV10 Digital Camera
Lexar Platinum II 4GB sd card won't work on my Polaroid PDC 3070
That card is not compatible with that camera. It's too large for an older model like that. Backup the card's contents and format it. It should work in newer models but probably not the PDC 3070.
Jan 16, 2009 | Samsung Digimax S730 Digital Camera
Card Error on a 4GB SDHC Sandisk Memory Card
I went onto the BestBuys site and found a link for compatible memory cards - The SanDisk SDHC isn't compatible with the Canon Poswershot SD750!! Only a 2GB card will work. The Lexar SD and the Kingston Technology 2GB will.
Dec 19, 2007 | SanDisk 4GB Secure Digital High Capacity...
Samsung Digimax A40 Digital Camera Logo
281 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
