Question about KitchenAid Food Mixers
Do you have an instruction booklet for kitchenaid attatchments thank you
  • 135 Answers
Hi possum. Go to the Kitchenaid website and look for your model #. There you can download info on your mixer. You may not find info for attachments though. If in doubt as to what speed to select for any particular attachment, always start at the lowest speed setting, then increase the speed until you can hear the mixer begin to struggle. Then select the next lower speed. If this solution helps you then please rate it. Good luck! ricardok45
Posted on Mar 05, 2009
How do I identify and order the part I need fixed on my Kitchenaid K5?
It is called the Bowl support. It is part #4 on the diagram in the. Instruction manual.. I
Aug 09, 2014 | KitchenAid 5KSM5BER K5 Heavy Duty Mixer...
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 15, 2013 | KitchenAid K45SS Classic Stand Mixer
Sunbeam fw6-a instruction booklet
You might be able to get information directly from Sunbeam
Jan 27, 2013 | Sunbeam Food Mixers
Cannot get dough hook out of slot pin seems stuck
run under hot water over where the dough hook attatches to shaft. this should free it.
Apr 23, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The wire whip hits the bow too much and makes a strong noise and ends up heating the bowl. what can I do to fix it? thanks
open the head of the mixer and there is a screw just below the area where the head is attatched to the base of the mixer. turn the screw counter-clockwise about 1 turn, try the mixer and see if it still does it. if it does then turn the screw another 1 turn etc. until the scraping stops. hope this helps :) from luke
Mar 26, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
Need a manual
KitchenAid has the manuals at their website. Click here for the use and care guide, and click here for instructions and recipes. Thanks for using Fixya!
Oct 02, 2010 | KitchenAid K45SS Classic Stand Mixer
My wifes Kitchen Aid ksmc50 (rrk90) mixer leaks grease/oil from the rotating plate that the beater/dough hook attatches to.The grease/oil leakes from around the outer edge of the plate as well as from...
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
Feb 15, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
106 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
