FixYa.com
Tags:
Panasonic ST-120 AX S-VHS Tape
S-vhs worse than vhs?
By kioner - usenet poster
After years of recording vhs, I got some svhs tapes and
figured I would now create better quality recordings. To
my surprise, the quality of the recording looks worse -
lots of noise etc. This under a very simple controlled
situation - catv cable plugged directly into vcr to record,
and vcr connected directly to display (via composite or
s-video) to play. Is this a common known situation, or is
something weird with my setup???
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
lawyer
lawyer - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hmmm...that VCR didn't have 19 micron EP heads and was optimized for
SP recording, IIRC. Hope you are trying in SP.
Most SVHS VCRs have *slightly* more video noise in SVHS than in VHS
because of the wider bandwidth of SVHS, but the increased resolution
more than made up for the noise increase. My HS-U795 has a great DNR
circuit which eliminates this problem.
Try a better tape. I usually use TDK XPSP ST-120 tapes, but I got a
GREAT deal on 1 1/2 cases of SONY MQST-120 broadcast quality tapes.
Bad tape can be quite noisy, especially in EP.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
VCR is a Mitsubishi HS-U770. I'm using Fujifilm ST-160 SVHS tapes.
Solution #3
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
Model of VCR? Type of tape?
Solution #4
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
It's a Mitsubishi HS-U770 - it's 7 years old, but definitely an
S-VHS recorder, and was a top-of-the-line unit when I bought
it. It has always served excellently as a regular VHS recorder.
Solution #5
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
"Ed Krauss" < @rwcrnsc52.ops.asp.att.net:
Do you have a sUPER vhs RECORDER. Which one?
Solution #6
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
Can you Help with these Audio and Video Media problems?
summer infant baby monitor
hi bought summer infant baby... Answer This...
Unlock dvdplayer
How can make my Philips PET... Answer This...
need a code to activate dvd...
Hi there, i have a phillips... Answer This...
Problem connecting USB Memory...
I have a new JVC component... Answer This...
registration
when i go to register my... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
