Question about Toshiba 35A44 35" TV
My toshiba model number 35a44 when turned on the volume down stays on and nothing else works i can turn it up but it turns back down
    Sergeant:
    Champion:
  • 318 Answers
The audio amplifier is faulty,
change the IC for your amplifier out put.
Posted on Apr 08, 2009
TOSHIBA 35a44 Chassis no. TAC 426. The TV volume started to go to 0 all by it self. When this happens the function stays active as if I'm commanding ''Volume Down'' ,(Remote or panel buttons),and no other...
Try to check the pannel and the remote "volume down" buttons - one of them could be stuck in a pressed position.
It usually happens on the remote when dirt or sticky substances accumulate around the rubber buttons - you need to disassemble the remote and clean the rubber pad and the remote housing with some ethyl alcohol and cottonwool, also clean well the holes on the housing where the buttons protrude.
If you also decide to clean the contact tabs on the rubber pad and the circuit board, you should clean them gently to avoid damaging the conductive coating.
I hope this helps somewhat.
regards
3rq8 (Triarcuate)
Sep 07, 2009 | Televison & Video
Toshiba 35a44 Tv keeps going to demo mode
let the card be cleaned with sprit, some contacts are still holding down.
that will solve your problem
Nov 12, 2008 | Toshiba 35A44 35" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Toshiba 35a44
your power supply is faulty check the following components
power transistor
rectifier diodes
zener diodes
fusable resistors
switch
Oct 02, 2008 | Toshiba 35A44 35" TV
this is the closed caption set to text 1 2 3 or 4 go into the settings and either turn cc on to cc1 or turn it off
Aug 08, 2008 | Toshiba 35A44 35" TV
Tv problem
le circuit logique n' est pas bon ,
il faut le changer absolument.
Jul 08, 2008 | Toshiba 35A44 35" TV
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Volume Issues with Television
toshiba 35a44 I had in shop would not turn on initially,when Qa01 was replaced I was able to turn tv on, but after a couple of minutes volume went all the way down, vol display bar on screen and power and menu keys would not work, remote control function did not mater. after replacement of QA02 mpu no results. desoldered volume down and up keys and sprayed chassis with flux remover on both sides of chassis and sumerged vol keys in alcohol solutions for 10 minutes, restored them in chassis and the problem was corrected. QA01 and QA02 did not had to be replaced there was a contaminant problem on solder flux that was causing the problem. kbzon
May 11, 2007 | Toshiba 35A44 35" TV
Toshiba 35A44 35" TV Logo
206 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
