Question about Numark PRO-TT2 Turntable
How to find a new platter???
I recently just came up on this Gemini 500 II turntable that someone was giving away and it has a platter from a different turntable. I wanted to know if anybody knows where I can get a platter that will fit the exact model and specs?
Htfr.com is quiet useful or look on ebay. 500s arent tht hard get equiptment for.
Posted on Mar 04, 2009
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
Gemini tt-2000 direct drive. Turntable platter is visibly warped, wow unacceptable. Flutter is also bad, piano suddenly has vibrato. What can be done? This is a new unit, bought last year, but because...
If the turntable platter is visibly warped there nothing you can do to correct this, the only option is contact the manufacture and see if they would be willing to supply you with a replacement part at no charge, especially when you have been moving. But I would check your warranty closely, you just might be in luck.
Feb 10, 2011 | Gemini Sound Products Gemini TT2000 Direct...
How to remove the platter in Gemini PT-2400 Turntable
hi,
firs of all remove from the mains. pull out the rubber bed over the platter. check whether there is any lock washer in the center shaft. if have remove it. if not its ok. now pull the platter towards upside by putting the fingers in to the holes provided on the platter. remember pull using ur two hands in opposite direction.
ok
Dec 30, 2010 | Gemini PT-2400 Turntable
I need a replacement cartridge for the gemini xl 500 ii series and i can't seem to find it in any stores or online.
Maybe this will be of help?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GEMSXL500II
Aug 03, 2010 | Gemini XL-500 Turntable
I just bought a set of Gemini 500 the belt has come off and I am usure how and where it fixes back on???
HELLO
This should be straightforward. Take off the slipmat and lift off the turntable (platter) and you'll see there is a rim on the underside of the platter this is where the belt goes.
Put the belt round that rim and you'll notice a couple of holes in the platter itself. Hold the belt through one of these holes and put it back on the tunrntable while taking notice of the motor position on the deck.
When the platter is in place (still hold belt) and move the platter to the position of the motor pulley and slip it on. Manually turn the deck once or twice to make sure it is in place - DONE! Replace the slipmat.
ENJOY! (:-)
Sep 13, 2009 | Gemini XL-500 Turntable
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
May 27, 2009 | Philips gemini XL-500 II Turntable
Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Apr 11, 2008 | Gemini PT-1000 II Turntable
32 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
