Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a coleman 6250 model pma525302 with no electricety
I went to flash the generator (I call it). I plugged alamp into it start the engine attached the negative to the negative and briefly touched the positive to the positive brush as told to in theoperator manual and the lamp will only stay on when the wires are touched to the brushes. What else do I need to do?
  • Anonymous Mar 05, 2009
    runs good but no electricety,how do you fix this, thay wont tack it back
  • 169 Answers
You probably have a problem in the field circuit of the generator, look here to see a general purpose solution I posted some time ago.
Carl
Posted on Mar 04, 2009
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
I have a tecumiseh 10 hp model hm100 that will not start. i have changed plugs, cleaned the carb, and ev eninstalled new coil. But still will not start, What is its problem? It is installed in a coleman...
Pull the starter rope and observe the ON/OFF switch. Does it flash as the engine spins? If so, you have found the problem! The flashing light in the switch indicates the engine oil is low. Add engine oil as needed to reset the AUTO-SHUTDOWN feature and it will run again. (If everything else is healthy.)
If this does not resolve the issue, reply to this post using the "Add Comments" option and we can further diagnose it.
Hope this helps,
Dolf-
Oct 17, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
Aug 16, 2009 | Coleman Powermate Premium Plus 6250W...
My Coleman Powermate 6250 generator has no power output. After the carburator was cleaned, I flashed it. A voltage meter shows there is power being generated, but none so to light a light bulb. What to do...
Take the cover off and flash the rotor again with a 12 volt battery. Positive lead goes to the top or right side brush. Negative to the other brush. Just touch it on, then remove it, and check for power at plugs.
If that doesn't do it, change the AVR (voltage regulator)
Aug 05, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Jul 30, 2009 | Electrical Supplies
I have a 3 year old Coleman Powermate 6250
Try this! To excite it. Shut off the generator! Unplug everything,Then use the 12 volt battery to excite it per manual. Make sure the engine is NOT running and the breaker switch is in the on position. Now with the battery 12V removed restart the generator! This should fix it if the problem is that it lost its magnetism.
Jun 08, 2009 | Coleman Powermate Premium Plus 6250W...
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
Generator runs does't put out electricety
Sounds like the brushes may have gotten fouled.
Here is a link to a general no output solution I posted a while ago.
Regards,
Carl
Feb 22, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
408 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
