Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP Officejet 7310 - Scanner Failure - Can't Remove ADF
I have the same 7310 scanner failure described in other threads: I can't copy, scan or fax from either the glass or the ADF. I'm trying to clean the underside of the glass and scanner parts, but I can't get the ADF off to allow access. I've read in threads for other models describing how to undo the latches or clasps to remove the ADF, but I can't find anything that describes exactly how to undo the ones on this particular model. I've tried using a thin-bladed screwdriver to "pop" them as described in other threads, but that hasn't worked so far. HP tech support was of no help at all, telling me the ADF can't be removed and it's impossible to clean the underside of the glass.
Could someone please tell me exactly how to remove the ADF on this model? Or does the glass come up some other way? I was able to remove all the Torx screws and the control panel and lift the glass up an inch or so, but that's where I got stuck. I'd really appreciate any help; otherwise, I have to buy a new unit. :-(
  • ScarlettV Mar 04, 2009
    I fixed my own problem, with assistance from someone who also owns a 7310 and had the same issues as I do. It turns out there are no latches or clasps at all, only hinges that have to be accessed from inside the rear gray cover at the top. The steps are as follows:
    1. Open the black ADF cover on the left side.
    2. Under the cover, release the "rear cover latch," which is a very small part at the back left side.
    3. Gently pry the rear gray cover off with a thin-bladed screwdriver.
    4. Lift the ADF unit and remove from the three hinges.
    I hope this info helps someone else!
    Genius:
  • 2,120 Answers
These printers are notorious for having bad scanners. The fix will not last long. Replace the printer.
Posted on Mar 05, 2009
    Novelist:
  • 180 Answers
Error such as this is hard to fix. I dont suggest that you need to undergo any repair on this one because it would cause you more than buying a new printer. Replace the printer.
Posted on Mar 10, 2009
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 7310 All-In-One product. The scanner has stopped working .... causing also the copier not to work and also the fax
Your best shot is to disconnect the scanner. Then uninstall ALL HP softwere using Control Panel, Add/Remove Programs. Then reinstall your HP software and follow the directions on screen for connecting the scanner.
Jul 23, 2008 | Office Equipment & Supplies
Vertical lines
hi,
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Can not fas from officejet
Are you having a problem with the scanner portion of the machine? When you place the original to scan into the ADF or on the glass, do you get a scanner error message? These machines have a history of scanner motors going bad.
Jul 13, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
967 people viewed this question
Ben Johnson
