Question about Artronix Technology Artec Ultima 2000 Flatbed Scanner
I have losted my cd and now how should i install artec 1236 P?
    Problem Solver:
  • 18 Answers
Click HERE to download the drivers for the following operating systems--
Windows 95/98/ME/NT/2000
If you are using XP, it probably won't work and it looks as though it isn't supported beyond the operating systems above.
After you click the link, you will need to wait 90 seconds before the download will start, don't click in the center of the screen it will try and get you to install something else. After the 90 seconds it will ask you to type in a code in a box, look at the image to the right of the box to get the code. Submit the code and voila.
Posted on Mar 03, 2009
  • shaunvfx Mar 05, 2009
    If I helped you solve your problem please rate my solution
    Thanks.
Hi I want to purchase a AC DC 12watt Power Adapter for my old ARTEC 1236P Scanner. Can someone tell me if I can use my spare Input 230V ~ 50Hz 9W (Output - 12 to 9v) adapter? If not what should be the...
This will mean the input on the first device is 120 V and input on the 2nd device is 230 V. Right? If so Yes you can use this if it belongs to the same scanner however you will have to plug the power into a 230 V Circuit. You cannot adjust, manipulate, change the Volts/Watts/Amps under any conditions. If the 203 V (Out put) plug is the same as the 120 V plug and there is a place to plug it in to the scanner then go for it. Volts/Amps/Wwatts/AC/DC are very specific to a specific device.
Jul 24, 2011 | Artronix Technology Artec 1236 P Flatbed...
My software is lost and i need to install the program inorder to run the scanner and use on my system
I have windows office but no disk for the artec 48u flatbed scanner is there a free download driver i could use to get it to work?
Jan 22, 2011 | Artec e+48u Flatbed Scanner
I just bought this scanner and have windows vista hooked it up and nothing. i do not have a disk
How to get the Artec 1236USB/Ultima 2000 scanner working in Windows Vista. Note that this how-to skips the various UAC prompts that occur throughout the process.
1. Right click on the Setup executable (whatever the name is, also assumes the full 22MB file) and then select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the scanner drivers and reboot the computer.
3. Go into Control Panel, select System, then select the Device Manager. Select the scanner, which should appear as an unknown item on the list. Right click on the unknown and select Properties, then select the Driver tab. Select the Update Driver button and let it search for the Artec drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for Scan32.exe or open an Explorer window and drill down to c:\windows\twain_32\artecusb\.
6. Right click on Scan32.exe and select the Compatibility tab. Set compatibility settings on scan32.exe to Windows XP SP2 and make sure the executable can run as an administrator.
7. If desired, repeat this process with ScnPanel.exe in c:\program files\artecusb\scanpanel\. My personal opinion is that ScnPanel.exe is redundant, the aforementioned scan32.exe file being far more flexible. It only serves to use up resources, so I wouldn't bother with making the file compatible and would just remove it from the Startup group.
8. Start scanning.
Hope this is helpful and fix the issue.
Thank you for contacting FixYa
*Please rate this solution with a thumbs up
Nov 16, 2010 | Artronix Technology Artec 1236 Flatbed...
Driver
The link to download is :-
http://www.downloadsource.net/18809/Artec-Ultima-2000-1236-USB-Scanner-Driver-Windows-98-ME-2000-XP/
Thanks.
Jun 17, 2009 | Artronix Technology Artec 1236 Flatbed...
Artec VOM-12E48X not reading software on DVD
Ditched the VOM-12E48X player and used a standard Artec WRR-52Z player. Did not require the ability to burn DVDs
Feb 18, 2009 | Artec (VOM-12E48X BR) DVD±RW Burner
No cd
http://www.driverslab.com/drivers/Scanner/Artec/Ultima_2000_2_92-Windows_98_Me_2000_XP/2333.html
Here is the driver for it.
Jan 24, 2009 | Artronix Technology Artec Ultima 2000...
DRIVER SCANNER ULTIMA 2000 /1236 USB
I just uploaded it for you here:
http://www.filefactory.com/file/ag7c765/n/Artec_Ultima_2000USB_2_92_With_EZ_Function_exe
Click on FREE DOWNLOAD and wait for the 30 second countdown then click on the big blue Download link that will appear. The file should start downloading. FYI... The filename only shows Ultima 2000 but it also contains the 1236 drivers as well. I renamed the file and forgot to put 1236 in there so don't worry.
Dec 15, 2008 | Artronix Technology Artec 1236 Flatbed...
Problem
Take a look here
http://www.driverforum.com/scanner4/7720.html
However if you are hoping to run it on an XP/Vista machiner you may be unlucky
Mar 19, 2008 | Office Equipment & Supplies
Artronix Technology Artec Ultima 2000 Flatbed Scanner Logo
132 people viewed this question
Top Artronix Technology Office Equipment & Supplies Experts
k24674
Are you an Artronix Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
