Question about Fossil BQ9184 Wrist Watch
Question:how to set the weekday on a Fossil watch model BQ-9165.
I recently received a Fossil wrist watch, model BQ9165.
Problem: I don't know how to set the weekday.
- day of month - pull out watch stem half-way and rotate
- time - pull out watch stem as far as is easy & set time the normal way.
But the steps to set the 24 hr dial and the day of week dial elude me.
Suggestions appreciated.
    Problem Solver:
  • 8 Answers
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Posted on Mar 03, 2009
Hello, I Recently bought Fossil Watch "Fossil Men's ME3027". Can anybody let me know how can I set weekday in the watch??
the link below will take you to Fossil instruction PDF page
https://www.fossil.com/uk/en/customer-care/watch-instructions.html
Aug 22, 2017 | Fossil Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
Replace battery for BQ8165
Take your watch to a jeweler for battery replacement.
Jun 30, 2014 | Fossil BQ9165 Wrist Watch
What is the type of battery for fossil BQ-9165?
Take your watch to a jeweler for battery identification and possible replacement.
Jun 20, 2014 | Fossil BQ9165 Wrist Watch
How to use a chronograph watch factions
Thank you for contacting FixYa.
  • Identify the push button that controls the second hand. With the watch face positioned so that 12 is at the top, locate the button on the right of the watch's rim and above the watch stem.
  • 2
    Grasp the watch stem tightly and tug it out, away from the watch rim. Pull it past the first area of resistance, a position used for other settings, to the second stage of resistance where it will not pull out any further.
  • 3
    Press the second hand push button, identified earlier, until it is firmly depressed into the watch rim. Release the button, allowing it to return to its normal position.
  • 4
    Push the watch stem back to its original position tight to the rim.
  • Jewel
    Sep 14, 2010 | Fossil BQ9165 Wrist Watch
    Fix date n month on wrist watch
    mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
    Jul 19, 2010 | Pulsar 5117 Wrist Watch
    Fossil bq 9011349908 cannot set date and day
    mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
    Jun 27, 2010 | Bulova Watch
    How do I use the chronograph on my watch?...Can't find any instructions online and I don't have the manual. Fossil bq-9165
    mcdevito 75 here, Check directly with Fossil on line for the manual, or check with your local watch repair shop.
    Jun 16, 2010 | Fossil BQ9165 Wrist Watch
    Fossil BQ9184 Wrist Watch Logo
    2,484 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
