Question about Sony Playstation 3 (PS3) Console
Unsure of how to connect PS3??
Hi i set up my PS3 by using a universal s.video & audio cable and have also tried the av cable for a PS2 and connected it to the av plugs on my t.v. The green light comes on the PS3 but nothing shows on the t.v???
Try changing the Sound and Display settings in the Settings Menu, otherwise call one of the customer service numbers found on the back page of any of your game manuals. Good luck
Posted on Mar 03, 2009
Ps3 won't go to AV
If you have recently used an HDMI cable, or other HD output, your Ps3 may still be set up for such a connection. If that's the case, you can try..
1. connecting with AV cables while your system is OFF. 2. Then, hold down the power button. Your console will beep once, keep holding it down until you hear a SECOND beep.
That resets your audio and video output to SD again.
Hope this helps.
Jan 28, 2012 | Sony Playstation 3 (PS3) Console
How can i get my ps3 to use the av cable instead of the HDMI cord
Hello there,
There is no way to connect an AV cable directly to a PS3; however, you can purchase a special cable that convert the HDMI to AV. Here is one such cable. http://www.amazon.com/Universal-S-Video-Audio-Cable-GameCube/dp/accessories/B000IAPGII
I hope this has helped! Thumbs up are much appreciated.
May 06, 2011 | Video Game Consoles & Games
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Fixed ps3 ylod but now no picture and sound. what could this be? and how could i fix it?
If your tv output it av (red white and yellow cables and av connection), then make sure you push the cables in properly. If that doesn't work then if you have a ps2, use that av cable and switch it with your ps3 one (theyre both the same). And if your output is hdmi, than either the cable is faulty, the tv or the ps3. And for av connection if none of those options worked then its probably your ps3.
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
Can't get video to work on Ps3 system compossite cables
First make sure that all of the connections are securely connected. If it still doesn't work try another set of cables. Also ensure that your setup menu on the PS3 is set to the correct resolution. If you are using the standard definition connection (3 RCA type connections labeled VIDEO L-AUDIO-R) make sure your resolution is set to 480i. If all of those steps are correct and you still can't get it to work then your Analog Video board might be defective. You will have to get this serviced by your local PS3 repair center.
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 No signal to the TV
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Ps and TV not connecting using av cable
when you turn on the ps3 hold the power button till the system beeps
Nov 15, 2008 | Sony PlayStation® 3 (60 GB) Console
No picture or sound
The PS3 works in some tvs only. Try connecting the HD cable in a tv and not the 3 Video and audio cable. Thats what happend to my PS3.
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Sony Playstation 3 (PS3) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
