Question about Pioneer Car Audio & Video
Pioneer amp wont come on. no light.
Prd2000t. remote shared w/another amp. it works fine
  • 117 Answers
Power light uses a resistor , it may be bad , try to use seperate turn on instead of splitting them close to ampo or right to it, try to use turn on to that asmp only in case its a power draw issue from head unit
Posted on Oct 29, 2009
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
....andy....
Jan 06, 2014 | Pioneer Car Audio & Video
Amp works fine but the power light is still on after jeep is turned off
Cut the remote positive on your amplifier, install a switch, that's one of the remedy, or you have to make sure that the remote positive of your amplifier is hooked up to the ignigion's positive, this way your amplifier is off soon as you switch off your ignition.
Jun 26, 2010 | Pioneer GM-5000T Car Audio Amplifier
My amp normaly has a continuious blue light when functioninng properley now it is at a fast blink and my subs wont work what is the problem i have checked the hot and ground and the remote wire .if i...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 01, 2010 | Pioneer GM-5300T Car Audio Amplifier
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
Amp not staying on
Hello lyttle_matt1,
Connect a DC voltmeter between the "remote" (+) terminal and the "ground" (-) terminal on the amp. When you turn on your Pioneer, you should read 12-14V. If you get voltage for a second and then it goes away, either the incorrect wire from the head unit is connected, or the head unit remote turn-on is defective. If the voltage remains on the terminal and the amp immediately turns back off, it's possible that the remote turn-on is not supplying adequate current for the amp. To determine if that is the case, run a separate wire from a positive (+) accessory terminal (cigarette lighter or fuse box) to the amp remote terminal. If the amp then turns on and stays on, you'll need to wire a relay into the turn-on wire. The wiring for such a relay is shown here. Most any 12V SPST or SPDT relay from an auto parts store or Radio Shack will work OK.
May 11, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Amp trouble
Check the remote turn on line from your deck & make sure there is 12 volts on it when everything is on. Check the ground, too.
Jun 30, 2007 | Pioneer GM-D510M Car Audio Amplifier
Car Audio & Video Logo
75 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
