Question about Maytag Neptune MAH5500B Front Load Washer
Washer will not agitate or spin. Will fill and pump out water but will not agitate or spin.
  • Maytag Master
  • 3,361 Answers
Check your belt. It is probably broken.
If not the belt, check your door switch.
Posted on Mar 03, 2009
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
