Question about Sharp AR-168D Copier
I have a sharp ar-168s printer/scanner ect combo. We have the printer networked through the manager?s computer. If pushing scan on any of the sc1-6 displays the scan goes directly to the manager?s computer. On my computer I can print to the printer however I can not scan or retrieve a scan from the printer. I have been all over the internet trying to fix this problem. When I called Sharp they would not help me because they do not support business machines and recommend going back to the company that we purchased the unit from. The original company closed there doors. I have reloaded the software several times and checked for updated drivers with no luck. So as of right now I scan the document and retrieve the scan from the manager?s computer. This takes up both our time and has been a tremendous hassle. Any help would be appreciated. Mike
  • Sharp Expert
  • 1,326 Answers
I am not 100% sure, but when you bought the copier how many "Rights" did you buy or recieve when the copier was installed? Most like you only got "Rights" for one user only and you may have to buy another legal or registered copy of the scanning software. Have you tried to have your "IT person" try to go on your network to give you the "Rights" to use the scanner?
Posted on Mar 03, 2009
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Nov 13, 2017 | Sharp AR-M162 All-In-One Laser Printer
I need the driver 4 sharp ar-c260 scanner driver
Has scanning been turned on with the product key? Is your Image Send button working? If so you can go to the web page and set up a scan to a network drive folder. Or buy Sharpdesk v.3.2 with the network scanner tool.
Aug 12, 2010 | Sharp AR-C260M All-In-One Printer
System error (f2-04) for model #AR 168S
f2 codes all have to do with the drum. have you replced the drum lately?
Dec 28, 2009 | Sharp Office Equipment & Supplies
System error (l4-01)
You have to check that the scanner is not blocked, it have knob lock to do this it is behind the scanner, also you can remove the glass and lubricate the scanner on the shaft.
jesus contreras ortega
Sep 06, 2009 | Sharp AR-168S Copier
Need code to reset AR 168S copier
yes i know you press c photo c photo then all light is off press up and down arrow key
Jun 11, 2009 | Sharp AR-168S All-In-One Laser Printer
Network scanning issue with sharp arm205
This machine can only scan across a network when the Sharp network box is installed and 512mb extra memory is installed in the copier
May 23, 2009 | Sharp AR-M205 Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
Computers cannot find the Sharp Scanner on the network
Are you using Sharpdesk? first check the firewalls, allow the exception, if that is not it, then from network scanner tool profiles, Change the Port, I believe it defaults to port 4687 - or 4689? (this uses an FTP port,) Allow this port in the exceptions. If the network scanner tool is not running, your machine will not communicate with the PC.
Jan 20, 2009 | Sharp AR-BC260 Color Copier
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-168D Copier Logo
166 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
