Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool calipso washing machine
Washing machine is fairly new have had no problems just quit working and shows CE on dispay screen. try to reset starts filling then turns off and displays code CE
  • mel orr Aug 12, 2007
    Do not have a service manual any help diagnosing problem would be greatly appreciated
  • 5,911 Answers
"CE" is a communications error between the motor controller and machine controller. This could be a simple problem of just a dirty contact, or it could be something more significant like a wiring harness or control board. There should be a tech sheet inside your washer on the front casing beside the wash tub. You will need to lift the top of the casing up to get to it. In order to do so, you will need to find the two retaining clips holding the top down. Insert a putty knife about 2 inches in from each side along the front seam and push in while lifting up. This will release the top and it will open up. Hold on the the lid as you lift the top as it will want to fall open. The tech sheet should be sealed in plastic on the casing. The troubleshooting steps, along with illustrations are all in this sheet. Both control boards are located inside the top console. Simply remove the screws along the back of the console to remove. Make sure you unplug the washer before attempting any readings. Use care when removing any of the wire connectors or handling the control boards. The wires, as well as, the control boards are delicate. If you do not have a tech sheet, let me know and I will guide you through the necessary steps to troubleshoot. I hope this helps.
Posted on Aug 05, 2007
Washer shuts off and dispayes blinking h f
im not quite sure but check how much your loading beacuse you might be overloading it. Or check the filter on the front.
Nov 01, 2012 | Whirlpool Washing Machines
Washer gets to 20 min left in rinse cycle recuriculation pump comes on and off anything from 5 seconds to 2 min control countdown stays at 20 min for over 20 min? whirlpool calipso
usually problem with digital washing machine is on the program module, exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hoseline.
Jul 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calipso model clothes washer shows a LD and doesnt run
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Code ce shows we have tried to reset and the code CE come up each time
"CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Nov 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GSW9800PW Won't Start
You may just look into replacing that switch. You shouldnt have to slam it, and by doing so could be causing damage. Its a cheap fix.
Oct 08, 2009 | Whirlpool GSW9800PW Washer
My washer keeps flashing CE code and turns off.
This indicates a communication error between the central control board and the motor control board. Since you said that the fuse is good, a common trouble spot to check is the quick disconnect at the motor connector. Sometimes, unplugging and reseating this connector will clear up the problem. (If you are lucky). Hope this helped and best wishes.
Aug 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calipso wash motion
your inlet filter is most likely plugged.
take of your hoses from the machine and clear the filters in the machine inlet ports.
If this does not help your inlet valves are broken.
But most likely the filters is the good bet
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
91 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
